Thanks, B350 it is then.A B350 is fine for your described needs. The main gain with an X370 is being able to SLI or Crossfire. As your not gaming that's of no interest to you.
Thanks. Just ordered it, seems to be stock coming in now at some retailers.Enjoy![]()
That's the thing I don't get, why they put X370 on itx boards? few of them look exactly the same B350 and X370 on itx format, or is there any difference that I'm missing?A B350 is fine for your described needs. The main gain with an X370 is being able to SLI or Crossfire. As your not gaming that's of no interest to you.
Make sure you get good ram and read this article here about how affects performance. (2666->3200 is 10-14% flat more fps)Thanks. Just ordered it, seems to be stock coming in now at some retailers.
So the other difference between X370 and B350 is you get more USB 3.1 G1 (6 instead of 2), you get 4 instead of 2 Sata and 8 instead of 6 PCI-e 2.X
With that though it does mean more connectivity overall but going for ITX it doesn't seem to be really needed from B350 either. The biggest reason honestly is selling point that it has X370 on it and so they can charge for it because people see it as the premium.
Given that all boards should support the 1800X, you don't have issues. If remembering correctly from a review only the Asrock mITX has power issues with the 1800X.And what about the phases (vrm) x370 had better (more) phases than the B350. Not per se better overclock but likely better temperature at higher clock speed, right?
Even the biostar mITX supports the 1800X @ 4Ghz on all cores. After that depends.
Imho the Asus B350 Strixx is the best. And several benchmarks I have seen it's performance is in par if not better than the X370s.
My only concern with the B350's is how they will get on with zen+ overclocking. They get toasty now.
Also the Zen+ will remain on same power consumption. The process raises the clocks not the voltage.
I don't disagree, however is the same as thinking how the power consumption will be in 6-8 months of the time.To be frank, that is a stupid statement. No one other than the peeps at AMD actually know what Zen+ will bring to the table. To casually make a statement like that as if it were a fact is just plain wrong.
Silversurfer posted this in the Vega thread:
http://i.imgur.com/fb4kFYB.png
It is basically a picture from an earlier AMD event but with a picture of the Eypc CPU with an IHS superimposed into the picture.
It does look at least one model of the APU is not really any smaller than the Ryzen CPU.
Yeah that's an old EPYC picture. The Threadripper has only 2 CPU modules, not 4.
I've got some 3000MHz Corsair LPX to go in from the current 6700k build. Not sure if it's Hynix or Samsung but hopefully get it running at its rated speed. I've got some 3600MHz G.skill running at 3200MHZ in my other Ryzen gaming PC.Make sure you get good ram and read this article here about how affects performance. (2666->3200 is 10-14% flat more fps)
https://community.amd.com/community...emory-oc-showdown-frequency-vs-memory-timings
Just finished my setup with the same msi mortar motherboard. What settings have you used to get your ram up to that? Currently at 2800mhz with 1.35v. Anything higher and it fails to boot. Not really spent much time tweaking it.Have my little system up and running, so far very happy with the performance of it. The 3200mhz ram i got upto 3066 so far and i can only guess with more updates it'll be running at full pelt soon enough. Even got a slight overclock of the cpu with it at 3750mhz, not entirely sure of the voltage, think its at stock or a little over it, still tinkering with some options.
Gaming performance is really good, some of the reviews stated 2500k performance gameplay, which is utter bs from what i'm seeing so far. Using a fury x on my previous matx board on a 2600k at 3.5 bf1 at 1440p would see dips down past the 60fps range even with some settings dialled down, this is running ultra with the same fury x locked to 60fps, the only time it dips to any degree is at the end of round screen where the camera zooms out from your character. Was doing similar before any overclock was involved though didn't play with it long enough at stock to see if this held out over different maps.
Just waiting on my am4 bracket arriving so i can plonk my liquid cooler onto it![]()
I have the dreaded v5.39 corsair vengeance lpx 3200 ram...
Seen a good 30fps increase in fps over my 3570k with the same gpu in bf1, without overclocking the ryzen 1700.
