- 5 Sep 2011
- Surrey
All part of the hype train, till reality sets in
Doesn't this mean that selling X399 board second hand will be a problem, since you won't be able to easily fit the cover back on?
Motherboard down!
how does the 1900x differ from the 1800x, would it be worth the extra £££ for the motherboard, they are both 8c.
cheers fancied a change may wait to see if anyone is selling an R7 setup on MM if they are upgrading to TR.More PCIe lanes and quad channel memory.
Also comes with a higher stock clock but I'm pretty sure everything amd is selling atm caps out at ~4GHz.
If you are not connecting enough stuff to use extra pcie lanes and dont have programs which benefit from quad vs dual channel memory then it's just a more expensive cpu and motherboard vs the 1800x
It seems they do come with a torx driver included![]()
In the video he says that, he damaged the pins when trying to put the protective cover back on. Admittedly we don't know the full story but assuming he knows what he is doing (considering that he got a review copy this is a fair statement), it implies to me that putting on the protective plate back on is quite a tricky task. Assuming he had difficulty putting it back on how much trouble will the average PC builder have?What are you on about.
There's the black pin protector, comes off, goes back over the pins again.
There's the transparent dummy cpu carrier that slides out, you can slide that back in again.
