Is it normal for my 3.8Ghz overclock to run at 3.79Ghz?
Sometimes in my imagination i see 3.8Ghz in CPU-Z and think that it's really 4.5Ghz........................................that's what i call looking into the future
Some extra cooling on my MSI B350 Tomahawk
VRM's getting a little too warm?
Yeh had a look at it today,think I'll put a 140mm on the top blowing cold air in for now.Have to admit, a mono block is awesome for this reason .
.After nearly a month of waiting, my Cryorig AM4 bracket finally arrived:
The cooler just about fits and does touch the glass panel.
Massive improvements compared to the Spire cooler, idle temps dropped from ~45c to 32c, max temps from 80c (if GPU is stressed too) to around 56c. Dropped the fan speeds too on the case and now I have a silent gaming PC. Honestly not sure if I want to overclock, I'm already very impressed with the gains I'm getting over the 4.2GHz 2600K.
I think Asrock do win 7 drivers utilities for some of their boards, check.So, having seen this deal on the Ryzen 1700x I'm more tempted than ever, but... I need to stick with win7 & probably also going Linux too.
I know it's not supported for the newer CPUs, but I'll have to live with that.
Anyone here using win7 with Ryzen? Any major problems? Easy sailing?
How easy was it to get it up & running?
I have no personal experience with windows 7 on Ryzen, but searching for specific chipset drivers for sound, network etc. may not be too difficult or the win10 drivers may work on win7.
How do you turn of telemetry?For point of interest, why do you need to stick with Win 7?
Maybe just my 2p, but people slam down on 10 more than is really justified. Trim out Cortana and turn off all the telemetry stuff and it's perfectly usable.
Some older software (hell, even some new software hehe) doesn't work in win10, so it's win7 only for me.
That & I refuse to have forced (even if slightly delayed) updates that can screw things up, reset my options/settings etc or worse, uninstall programs because it thinks they're dodgy etc.
Plus, adverts in an OS, nope!![]()
Seriously, I do that, then once a month when it's convenient I manually enable it, get it done, turn updates off again.
Just disable updatesSeriously, I do that, then once a month when it's convenient I manually enable it, get it done, turn updates off again.
And I have never seen an advert in Win 10, where have you gotten that from?![]()
Thanks I will try that today.Blackbird is one easy way to do it.
http://www.majorgeeks.com/files/details/blackbird.html
Things changed since I recently looked?
Thought you couldn't completely block updates unless you had the top tier of windows & even in the agreement it states they can just turn things on again.
Ads I've seen mentioned on reddit, stuff like apps getting junked into start menu.
