Here's a write up of the DP2 fixes. Looking good.
There was a lot to check out here and I wanted to answer a lot of questions that many of us have about the 8.1 DP2. Here's what I found out:
Audio Quality is fixed when recording video. I tested this with a fan and it's a huge difference.
The mic used to record audio is no longer the bottom front speaker but now the top edge speaker (the tiny hole along the bezel).
External mics still do not work on the stock video app. This stinks.
The Unresponsive Edge issue is gone. I dare say it seems perfect.
Saturation mode is added, but other modes are not calibrated. Reds on natural and boosted still look awful and "dried blood red."
The Camera HDR+ HAL may result in the following: double-click on the power button to launch is faster, the speed of taking a picture will sometimes be the same speed as pre-update, but more often than not, noticeably faster.
Black crush is still present and gets worse the more you decrease the brightness.
Using the mic from a Bluetooth device now works with the Google Assistant.
With that, asking the Assistant to translate for you launches the app, but when you talked to it, it just translates and speaks back into your Bluetooth device rather than out of your phone and vice versa. The Pixel Buds translation interaction is an exclusive feature.
Navbar shows up as white more often and fades out to prevent burn-in.
Check out the video of the tests, how to enable certain things, and a weird thing I noticed between the Black & White version and the Just Black version:
PS: Thank you /u/lakerzz /u/mixplate /u/GameShowKid /u/rigamix for giving me some things to check out.
I knew working on the video tonight would mean it will be a late night. I still haven't gone to bed yet and I have to be at work in three hours. I'm going to need a lot of coffee...ZZzzzZZzzz
https://www.reddit.com/r/googlepixel/comments/7g3vut
