- 1 Dec 2015
Might be game is running in 4k instead of 1440p ?
Have you Installed Nvidia Geforce Experience ?
Not the best but you can edit settings before launching a game..
https://www.nvidia.com/en-us/geforce/geforce-experience/
With the One X, I'm pretty sure you can stream from one system to the other ? If your other half is on PC, should be able to stream your game to the Xbox ... Good for though or opposite way
Also , is the Division Saved to SSD ?
Load times should be 70 quicker then Xbox due to SSD and Sata3 connection. Know standard Xbox one only use Sata2 for storage speed
It took a bit of persuading with the misses to invest and all I’ve done since I got it is take it apart and have problems running things, even she’s giving me stick, “I told you it was a waste of money and you should have stuck with your Xbox”
