Spec me a CCTV System
5 Aug 2013
Shropshire
Hope this hasn't already been asked
My 7608 is in loft with long HDMI lead down to monitor by the PC (I am in a bungalow) Was watching TV earlier and thought it would be nice to switch HDMI channels and get the cameras up - so googled and can get a HDMI splitter - So if I run another HDMI from splitter to TV will it work - Monitor and TV are 1080 - has anyone done this ? - Goodness knows why I have only just thought of it - systems been in nearly 3 years - Up to date I have not had any problems except it asks me occasionally for more secure passwords - just click no and it carries on as normal.
11 Dec 2004
I use a HDMI slitter on a sky box to feed two TVs with the same picture and it works fine, don't know anything about the gear you are using but HDMI should be standard protocol. The only issue I had was when the TV's had different resolutions one would stay blank until I set them to match, but if everything in the system is 1080 then I think it should be ok.
5 Aug 2013
Shropshire
Have you got a expensive or cheap splitter - prices ranged from 12 to hundreds of pounds but 25 was price range I looked in
That's why I checked both for resolution as I read the splitter checks and set's itself for lowest - if you turn one off at mains then it rechecks and sends correct signal to the other -
Need to measure up how long a HDMI cable I will need - From what I read you should use reasonably good quality cables but I heard that in my HiFi days and for what I had it didn't make any difference.
20 Oct 2013
Yorkshire
You make it sound like I know what I'm talking about :D ha
I got 2342s from XinRay Store and 2335's from HIK Security Professional Store
Keep an eye on your aliexpress messages as they will message you there with regards to shipping info.
Did you get stung for any import taxes on your order? I have just placed an order from HIK professional store and they have messaged me asking me how much value they should declare?
25 Feb 2009
Im currently using Nest cam pointing out a window. Im moving house shortly and i need to monitor a 30m garden. I was thinking of just getting a couple of outdoor nest cams but priced it up and thought id check for alternatives! Can anyone point me to the best place to buy/research home CCTV? my budget is around £400 bit more bit less depending.
Also, is there such thing as an underwater camera? that could be on the same network?
So finally moved into the house last week and definitely need to get some cameras installed. I've got multiple blind spots and various points where people could jump over the fence. I think I could cover the garden arena with 4 cameras, then one for the side.
Hopefully someone can advise if i get some pics in the morning.
I've been using nest cam for the last couple years and really like the way the app works for notifications and the speed it connects at. Are the CCTV apps that come with these cameras similar to the nest app?
11 Oct 2011
UK
Hikvision app supports push notifications and seems decent to me so far
18 Oct 2002
The Darkside
Saw this last week on a new cam install but starts of dark and after a few seconds it brightens up. Had to recrimp the connector at the cam. Poor connection meant Speed/bandwidth issues.
Man of Honour
11 Dec 2002
Darkest Norfolk
tempted to get a few ds-2cd2335fwd-i to start playing with a setup two questions though:
- is there any guidance as to working out which lens angle you go for?
- Im planning on using my diskstation to start of with which appears to work, but when i want to move on from that what base unit (?) are people using with it
11 Oct 2011
UK
There are a few demo videos on YouTube which should be sufficient.
Also bear in mind that the wider the lens, the less the 'quality' of the image as you've got the same amount of pixels still but over a larger area.
*NVR
See post 1652 for mine :)
4 Feb 2007
Nuneaton, UK
I haven't updated any of my HIK cameras or the NVR as all I read was horror stories, people seem to have major problems or features get removed, anyone else found this? Not upgrading firmware or software goes against the normal advise for most prducts.
31 Oct 2002
Newcastle upon Tyne
My Hikvision and monitor are currently under the stairs but I'd prefer to have the monitor elsewhere. I've got Cat 6 throughout my house so could I use an HDMI to ethernet extender box thingy? Does anyone have any experience of these?
