Stuff..
Bizarre. What PSU are you using and are you using separate cables for each 8PIN?
First I had a corsair cx750m but sent it back because of this problem, then got a kolink 1000w and the problem continued.What power supply do you have?
and some are saying Win 10 is better than 7.![]()
Here's a review of each card from the same reviewer, so good data points.I'm looking at the PowerColor Red Devil vs. Sapphire Nitro+ Vega 64s now. Any pros/cons between either (price differences notwithstanding)? They seem like very similar beasts...
I'm coming over from the Green team (Auros 1080 ti) and am looking to take advantage of my Freesync display.
I've never heard of that PSU and it looks to be a budget PSU.First I had a corsair cx750m but sent it back because of this problem, then got a kolink 1000w and the problem continued.
But surely under all that overclocking stress and all those stress test programs (i was trying to crash it but it wouldn't) it would have hard reset if it was the PSU?
Yet it only happens when running a game.. Stock, OC'd doesnt matter same result.
The corsair CX range is a budget range and I've never heard of of Kolink.I'm guessing there's no help here for me then , i'll just go kookoo then![]()
Or Leadex. Leadex are my go to for PSUs.The corsair CX range is a budget range and I've never heard of of Kolink.
One name, Seasonic and don't look back.
Do you have something of higher quality you can try?
For gaming this proves otherwise, It's Tit for Tat.
The only real advantage is due to M$ blocking DX12 on Win 7.
Indeed, their Gold/Platinum units usually get good reviews: http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=521Kolink seem decent enough from what I've read, an up and comer.
Avoid their Bronze and 80+ ones though, unless you're trying to start a fire.
He is using the Bronze version.Indeed, their Gold/Platinum units usually get good reviews: http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=521
When i see a 1000W power supply priced at £48 and £70 respectively, i do worry.
