Man of Honour
- 21 Nov 2004
Won't they either a) be blown out
Wonderful for the person behind on a big straight
I would also worry about the flow out of those.
Points for trying though
Points for trying though![]()
The design is such that the perforations on the inner section equal the size of the standard pipe but if theres too much pressure it can actually flow around the outside edge![]()
There is an inside lip which the bolts catch onto to prevent them being blown out.
I would still bung and extra nut on to each bolt to lock them up tight...I wouldn't be surprised to see the vibrations work those bolts undone in fairly short order.
Nice! Is that because it's due disc/pad replacement anyway, or just because?![]()
Niiiiice. They're awesome when you can afford them. When i was looking at m4s the dealer was telling me how loads of people were part xing the cars when it was replacement time simply because of the cost! Sure he said they were something like a 5k option but you were looking at more than that at replacement time.
Went in, dropped the workshop lads off 2 big packs of doughnuts before heading into the office to speak to Iain Litchfield and Neil.
Humour me..... How much were the discs? lol
