Man of Honour
- 13 Nov 2009
- Northampton
Levelled at the corners then approx 100mm from the corner, bed has very little warp checking with a straight edge. I doAre you checking for level in the centre of the build plate as well as the edges? Most platforms aren’t level and naturally most people check for level in the corners which are often higher than the centre where most parts are printed
@Frozennova which slicer and what profile?
Also https://www.simplify3d.com/support/print-quality-troubleshooting/ for tips.
Latest Cura using the CR10 Profile with adjusted bed size as that's what a lot of people seem to suggest for getting started.
