The Turing RTX 2080 Ti Owners Thread
Well it's free and is a good test. It doesn't use SLI at all.
Here are some results
9 Series Titan X @ 1216/7012
i7-5930K @ 4.4GHz
Driver 411.70
2080Ti 1935/7000
i7-5930K @ 4.4GHz
Driver 411.70
A 95% increase to the frame rate.
Forza seems super well optimised and 4K ultra is a breeze even on a 2080/1080Ti. 2080Ti is overkill unless you have a 144hz 4K monitor.
On the absolute max settings (see above) and with MSAA x4 (which is what the Xbox One X has) it gets 74fps average and 66 minimum
Not really overkill if you want a locked 4k/60hz
And this is Forza Horizon 4, not Forza 7 (which is a lot less taxing)
Yeah, but you're paying nearly twice as much for those extra few frames. Value must be considered... unless money is truly no object.
Well, finally finished resolving the stripped out old build for my temp rig. Ended up buying the cheap monsoon pump housing to remove the old kit and focus on building the new one for a while. Massively empty but still used copper as a last outing ;)
Oh and these fell in there ;)
More to follow but will probably move it over to a build log next week to show how I’ve already taken a drill to my 1000D :D
Time to bench on air, I will not be putting the blocks on until they go in the new rig (even if they are staring at me right now!)
I see your build inspiring my CyberPunk 2077 build :)
If you want to talk about the industrial looking copper joints let me know mate, been at those a long while now - even have a stock of them in 16mm ;)
Awesome, I will do. Expecting to do my custom loop around March (too busy until then) will be doing another rig for my wife too although hers will likely be pink/rgb (for her twitch stream).
Moar pics!
i7-5930K @ 4.4GHz
Driver 411.70
2080Ti 1935/7000
i7-5930K @ 4.4GHz
Driver 411.70
I will do a bench thread later.
I have all the bits I need to start it.:)
After waiting and waiting finally here! :)
I never get Haribo btw :( why you guys do that to me :p
jvzOnjB
Welcome and on TROH.:)
The Roll of Honour.
Date 29/09/2018, Make Palit GamingPro, mrozik, Link
Date 28/09/2018, Make Palit GamingPro, Silent_Scone, Link
Date 28/09/2018, Make Gigabyte Windforce, Quartz, Link
Date 27/09/2018, Make Gigabyte Gaming, GordyR, Link
Date 26/09/2018, Make EVGA XC Ultra, spikerules, Link
Date 25/09/2018, Make MSI Duke, Smffy, Link
Date 20/09/2018, Make Zotac Gaming Edition, LegendaryDread, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 2080 Ti.
Have any of you tried to play SoTomb Raider with an OC?
I can run Timespy and the benchmark in the game fine.
Go to play the game with an actual OC and it crashes with a dx error!
I am on the Dual OC Asus 2080ti
