@seanyc5 did you send your card back for rma yet?
I've now been having my computer turn completely off at random for the past week. I have no other GPU to test whether it's the cause. Not sure if it's the power supply or the PSU either.
God this is frustrating I can't play or do anything.
No mate not had chance been crazy busy, you get 28 days though. Working all weekend as well. Hopefully get it sent towards the end of the week.
I have managed to catch a Hitman 2 crash to desktop after about 30seconds and might try and catch a few more.
How you getting on heard anything back?
yes mate they have replaced mine wanted a msi ventus but got a zotac 2080ti be with me next week ..
How come you couldnt choose? you could have paid the difference in price I assume if there was one?
What card is it? Mine did this but straight after it loaded into windows and at desktop. I thought PSU but swapped out my 2080Ti for my old 980Ti after the 2080Ti died on me and not had any of them power off then boot to desktop then off again etc etc.
https://www.overclockers.co.uk/giga...ddr6-pci-express-graphics-card-gx-1a6-gi.html
Up in price another £60.![]()
That's to cover all the RMAs![]()
I was fortunate to have a spare 1000w superflower platinum PSU to hand so swapped that for my also two week old Corsair RM1000i and still had the same issues so knew it was my GPU thenAorus Xtreme. I'm RMAing the PSU first of all and then take it from there, I have a feeling it's the GPU though. It happens at idle and under load but quicker when the GPU is under load.
^ it's not had good reviews really either, its at best an average card with a couple of led's slapped onto it. The pricing on it is hilarious as well, nearly £1500 for a card that's easily beaten in thermals and acoustics by cards much cheaper.
