100mhz boost
Who is looking at just the 3600 and 3600x?
I doubt most of us can afford the price premium of the more expensive chips. £400 for a 3800x and intel equivalent sounds a bit rich.
When did processors start costing this much ? I’m sure once we spent £150 for core i5’s and £250 for core i7 flagships. What happened ?
The design.... Id rather have 1x8core chiplet than 2x4core ones Totally worth the extra price !!! 1x8 will be superrior on latencies simple as that.
Lower TDP and price. You think that extra 300mhz base clock and 100mhz lower boost clocks would make 40w difference ?? If that would be the case and both are 1x8core chiplets. God those cpus will like voltsWhat make you think the 3700X is dual CPU Chiplet?
Thank God we haven't got this to look forward too.![]()
The 3700X has a TDP of 65 Watts with the 3800X 105 Watts.
surly if the 3700X has that extra 8 core CPU chiplet the TDP would be higher, not lower?
Can be also the case of being other way around. But thats what I think difference is.The 3700X has a TDP of 65 Watts with the 3800X 105 Watts.
The alternative is you're suggesting 100mhz = 40W
Has anyone seen anything more about this supposed secret sauce hardware Asus are implementing into their mobos? Allegedly improves RAM overclocking considerably.
That's a very good point. I'm going to don a flame proof suit... Could we see an 8 core, single chiplet, 105w 5GHz part? Would be masterful sandbagging
The 3800X is the higher clocked, 100Mhz.
I'm saying with 2X CPU chiplets vs 1 the one with 2X wouldn't have a lower TDP.
Pretty mad that the gaming world is buzzing with excitement. For the fact that. AMD just matched a cpu already on the market from intel. For around the same price.
I dissapoint.
So one of the Ryzen 2XXX series i would see a massive performance boost over my current i7-4770K @ 4.2Ghz if keeping just my GPU from my system in my sig?
