So hold on, a 2500K 4c/4t is fine, but a CPU that has 3x as many threads and is potentially faster than an 8700K at total cost just over than of said CPU or the 8c/8t 9700K? You don't think that if you get a £189 CPU, that the saved £110 won't buy you a faster CPU by the time your 6c/12t part is too slow and you'll have spent the same or less money in total?
Also the board I listed is a brand new X570 board, not an old one at £139, what extra is that £80 more going to get you? Also what RAM are you buying for £160 that is going to be over 100% faster than the same amount of RAM from a different brand at £65-75?
If you had bought an i7 2600K not a 2500K I think your argument would be more valid, but you went for the budget option then, what is wrong with it now?
What boards do people fancy? We should poll it.
Different times. Back in 2011 single threaded perf was king. 2500K was not a budget option... it was the 2nd best chip in the lineup, for gaming and single-thread performance.
And look how long that 2500K lasted.... years and years. In the last couple years it's been flagging a bit.
The fact is I don't expect a 6 core CPU to have the same longevity today. Game devs are increasingly able to use multiple cores. And the PS5 will dictate some of that. 8c/16t in the new consoles - and fast cores - will dictate that PC gamers will also need 8+ cores. Esp with Windows, AV on top.
I fully expect a 6-core PC CPU to deliver a sub-console standard performance within a couple years at most. It's not going to be the next 2500K imho.
At least on AM4 even if you go 6c now you know 16c will be an option years down the line.
Depending on your mobo![]()
I've only had asus before. Defo fancy a change.The Gigabyte X570 Aorus Xtreme (passively cooled chipset) looks interesting.
I would definitely be looking for one that at least has a zero rpm fan mode based on the chipset temp (some of MSI X570's do).
Might not support the demands 16c needs to operate (power, vrms, temps)In what respect do you think the MB will make a difference?
Which boards are you keen on?It’s just a shame their BIOS sucks![]()
Apparently there is completely new bios coming with new boards for giga.It’s just a shame their BIOS sucks![]()
Manufacturer, Tier, VRM cooling, VRM power delivery...
I like the taichi, but the looks are meh. Gears?
