** The AMD Navi Thread **
Caporegime
18 Sep 2009
Dormanstown.
My point still stands, if they are starting to "cool phones with liquid" (i'll put it that way)
Then it shouldn't be a stretch that the consoles will be "cooled with liquid" either in a custom closed loop or some other fancy way, was the point to get back on track.
No the point doesn't stand.
Vapour Chamber stuff has existed for a long long time.
I'm sure even in conventional heat sinks there's fluid.
Consoles already have the vapour chamber stuff now.
26 Sep 2017
In the Masonic Temple
It's still liquid cooling though isn't it.... liquid turns to vapour turns to liquid, you semantic ****s
And in these phones that you are ignoring its not the same as a ATI 3870, I give up, this forum is more toxic everyday.
The consoles might be liquid cooled, it's not a drunk/idiot idea as you guys rudely jumped in with when it was suggested by someone else.
Talk navi now...
Caporegime
18 Sep 2009
Dormanstown.
It's not semantics.
It's akin to referring to a stock reference Vega 64 as watercooled. It's not the case.
You've taken something and tried to make it into something else.
EDIT : You can't refer to the forum as toxic because you've came out with a claim that's incorrect.
I don't think I was rude in my reply. I simply said there's no chance consoles will get an AIO.
26 Sep 2017
It's not semantics.
No i tried to defend someones idea that they could watercool the consoles, 3 seperate people jumped in saying it was madness and they were stupid. I tried to say it wasn't so crazy and this happens.
21 Mar 2012
I don't think they would water cool the consoles, unless there was an easy open and check/fill thing but the normies would never open the console, power on and disc eject is all they do, wouldn't work
18 Oct 2002
I think it is fair to assume that the new consoles will be in the 150w-180w power draw range. Minus 40W-45W for the CPU it will be interesting to see what they can eek out of the remaining 140W.
I think we are looking at FE GTX1080(non-ti) speed for the AMD GPU, which is not shabby at all.
It will be interesting to see how the boost clocks play out in the real world as will the cooling system.
6 Feb 2019
Trying to claim a vapour chamber is watercooling holds the same value to tech people here as turning your console on and dropping it into a bathtub of water and claiming it’s watercooling. We see through the marketing gimmicks
And the idea that it’s new is also false
If I take you at your word
Consoles are already watercooled long before your phones even used it
Caporegime
18 Sep 2009
Dormanstown.
I'm real interested in the next generation consoles.
But there was a crap ton of hyperbole with the original announcement. 8K, 4K 120HZ. None of which will be close to reality that games will target.
Based on the strength of the Xbox One X GPU I'm optimistic of upwards to 1080 performance from them GPU wise.
Caporegime
18 Sep 2009
Dormanstown.
Sorry I opened my mouth now with the crazy out of the world idea lol
How dare Sony and Microsoft use water.
It's not an of this works suggestion but it's not really realistic.
Microsoft would have probably used it in the announcement too if it was happening, or we'd have had leaks etc.
So it's simply not happening with the next generation consoles.
If the consoles come out and they're sporting AIO's I'm happy for you to requote me with "Owned'
16 Nov 2013
Pretty sure you dont want leaks with water . :p
18 Oct 2002
Yeah, too much cost and moving parts for an AIO. If there is one thing that manufacturers hate is moving parts.
The good old Dreamcast (early gen.) had liquid inside its tiny cooling pipes though. Counts as a phase change :D
