If it has changed they've kept it quiet, i can't see it myself but something must be causing TDP numbers to be all out of whack in relation to core counts and frequencies.
Yup.I wish there was way to calculate effective latency with this chonking cache though, raw latency seems to be misleading.
Yes. The B550 chipset will coexist with cheaper boards (no PCIe 4.0). Looking at the prices of these X570 boards, I think I may hold off to see what B550 boards there will be.
I thought asmedia developed or are developing a PCI-e 4.0 chipset for B550
The last I heard, PCIe 4.0 was being kept for X570 boards because of the expenses involved in the board design. Whether that has changed, I don't know.
Yup.
By my calculations 3rd gen Ryzen would need to be going to memory 36-40% less often as a result of the doubled L3 in order to bring effective latency down to being on a par with 9th gen Intel. IIRC, the initial indications are 10ns to L3 and 67ns to memory, versus 10ns to L3 and 47ns to memory with Intel.
Just a scant browse confirms what you said at least untill 2020. So realistically what your getting is X470 rebrand to b550 by looks of it
Yup.
They were taken from various other benchmarks where a common theme of 67ns was showing up, which for the most part has been consistent with what Zen+ was offering.Where do you get your "initial indications" from ? Even Zen+ get's better latency than 10ns to L3 and 67ns to Memory and that's with Memory at 3533Mhz. Zen 2's sweet spot is supposed to be 3733Mhz.
I would expect Zen 2 Memory to be 58/59ns and L3 8/9ns
The real take home is the headline memory latency number means very little; Zen 2 will require fewer trips to memory due to it's design. Fewer trips to memory equates to lower real world latency. Lower real world latency equates to better real world performance.
What matters is how much the increase in L3 cache reduces the trips required to memory. It'll vary by workload, clearly.
My instinct tells me that node shrinks with next generations might be taken up by larger L3 rather than extra cores; they already take up around 50% of die space.
While using old separate high and low side FETs+drivers design they're certainly decent.so far I have only ever had Asus or gigabyte motherboards, but what about MSI gaming carbon pro - aren't they meant to have good vrms and power delivery?
Thermodynamics, which if we had wrong would make most machinery not work, tells this:TDP and power consumption are two different things. 3900X will probably consume more power even though both have a 105 TDP.
Yes, but what does that have to do with the Crosshair VIII Hero? Just because Asus are slapping on a few more components and charging a fortune doesn't mean the tier below will be just as expensive, and it doesn't mean it'll be much more affordable. We don't know yet.The last two bits won't add £400 to the cost of a motherboard especially if they are using a cheaper Ethernet chip.
It cannot be chipset pricing either as we are having sub £200 X570 motherboards too.
Asus are testing the market to see if they can get enough people to buy the Titan equivalent of a motherboard.
Intel confuses people because they put the "@ 3.6 GHz" in the ID string of the CPU itself. It does not mean the CPU is running at that base frequency, because in almost all cases it will actually be running at its boost clocks (e.g. 5.0 GHz for i9-9900K on a single core at stock).That confuses me, why is the intel chip at 3.6, surely those things can do 5? Which should give it about 40% more perf?
No, the software isn't "reading" any frequency from any "firmware" at all.Its just what the software is reading, its reading the base frequency from the CPU's firmware data.
An interesting thing to note, all the Ryzen CPU's do not have a frequency reading.
