According to ASRock's motherboard descriptions, official support for 2x dual rank sticks on Matisse is 3200 MT/s, so that should be the minimum the IMC can do. For reference, Pinnacle Ridge was 2933 MT/s.sad to see people excited about 16GB ram kits.
Its 2019, 16GB is no longer enough!
Any dual rank compatibility or performance gain info?
B550 will still be ASMedia and only to PCIe 3.0 standard.
How do you know this? It seems very unlikely that B550 won't have PCIE4.0.
The chipset sure, but the CPU is still PCIe 4 with the much-improved IMC. With X570 prices being as high as they are, they're going to be enthusiast, almost niche purchases, there is no way in hell AMD will have gone to the trouble of better IMC and PCIe 4 if it was restricted to low-volume niche sales.
B550 will have a PCIe 4 option for 1 GPU and 1 NVMe SSD as that's bolted directly to the CPU and within 6 inches, everything else will be PCIe 3 so the board as a whole doesn't need a server-grade PCB and retimers all over the shop.
Will the b450 carbon pro be ok with the 16 core 3950x at stock?
Link us a game benchmark that proofs that 16gb is not enough.. After windows loads im sitting at 14300 free physical memory. I Think Division 2 barely hits 7000mb@4k from what I'w seen rescently. Monster Hunter World was around 6000mbsad to see people excited about 16GB ram kits.
This question in a thread where many try to find an excuse to justify 12 or 16 core cpu?According to who? and doing what? Theirs a very informative video on you tube that shows difference between 8gb, 16gb and 32gb in a lot of modern games, from 8gb -16 their was marginal difference and between 16gb to 32 their was zero difference and most games did not come close to using the 16gb
Naaaa Ryzen likes Dual rank on 32mb kits 2 sticks > 4 sticks but allot depends on Motherboard. Crosshair 6 was better on 4 sticks Crosshair 7 with 2 sticks. That's what Asus told us about changes made in design.This question in a thread where many try to find an excuse to justify 12 or 16 core cpu?
Judging from that video would you consider 8gb enough? All it tells you is that a gaming benchmark is a bad judge on ram capacity.
Anyway, I want more ram. And I remember Ryzen liking dual rank, so really curious if that 3733 sweet spot becomes even sweeter with high end dual rank 32GB kits.
(... its not enough... for me?..)
At this point I cant see me going 32 anytime soon. I will with Zen4 and DDR5 in 2021![]()
I've already got some Team Group B-die 3200C14 stuff. I'm saying if he's supposedly found a set of B-Die 3200C14 stuff for £70-80, then it probably isn't B-die.
