is there anybody running the 3900x with the Mini ITX Aorus x570 pro wifi? i think im about to purchase one as ive had a few more issues with the MSI b450. And im unsure if its best to use an offset for the voltages etc. . ?
Im using a -0.100v offset on my MSI X470 and its been running fine all this week![]()
yea ram can run pretty high voltage wise without any issues at all.hmm, bumped up my ram to 1.37 from 1.35 and seems to fix the crashing, am i ok to run at that - its rated at 1.35
Here you go fella, I started with these and then lowered a few of them over time a tiny bit like the trfc and trcThank you
Have to give a try as my ram can do 4133C17 on the Z370 platform and can do 3800C16 & 3866C16 easily. 3800C14 while can be done some times is unstable, so something is just amiss to get to the holy grail of 3800C14
If I can put together a similar set of settings like yours, maybe could be able to push it correctly![]()
Yes but that is my settings, numbers don't ageThanks but that looks like the old calculator from August yes?
If you are all core oc, you need to disable the pbo in the bios my friendStupid question time. How do I fix my clocks in game? With the 4.3 all core overclock set Ryzen Master is still showing cores sleeping on the desktop. A run of Cinebench R20 will have them all at 4.3Ghz but under gaming the clocks are varying and not getting close to 4.3Ghz. Are there some power states I need to disable in the BIOS? I've tried disabling all C states and AMD Cool and Quite but no difference.
Thanks but that didn't work. Tried turning off all the auto overlooking options I could find without any further success.If you are all core oc, you need to disable the pbo in the bios my friend
