MSFS2020 looks great on the G9
Just remember that you can't run the G9 At max Res, 10bit HDR @240hz, as bandwidth is to large for DP1.4
But still looks great at max Res 10bit 120hz, and anyway at ultra setti gs you will be lucky to 35-50fps in MSFS
this is a shame, why offer hdr1000 with this spec if you can’t hit it. Is the max bandwidth for that 120fps?
You need to format a smallish usb drive, say 16mb or so, save it to that, insert usb drive into monitor usb slot, then use monitor OSD to locate it and update firmware, I THINK that’s how it’s done.Hi guys I'm trying to download the Korean ver 1005.3 for my g9 but it downloads as a disk image. What am I doing wrong
The G9 supports display stream compression (dsc), you can run 10bit HDR @240hz if your GPU supports it.
Yer iv have the usb formated its just when I download the file it say wright to a diskYou need to format a smallish usb drive, say 16mb or so, save it to that, insert usb drive into monitor usb slot, then use monitor OSD to locate it and update firmware, I THINK that’s how it’s done.
I can definitely see a difference between 120-240Hz in games like Overwatch and other first person shooters, and it does help (Linus did a video on this if you're interestedDo you notice the difference? Can't say I can at just 60-120 fps?
Yer i think it is an exe fileIs the korean update an exe file for the G9 ?
it is for the G7
I just ran the exe and it auto extracted the file to one of my externals ready for me to put on mem pen.
