Nvidia 30X0 series waterblocks
I'm waiting on the EK block for 3090 FE.
In the meantime for anyone who hasn't seen it, Jay gave a good explanation about the various board designs available and more importantly for this forum, what that means for water cooling.
I can't recall the exact time the discussion about water cooling specifically starts (I think around 7/8 minutes) but here you go:
There's a couple of stores selling them. Both similar prices. Just search for Bykski and 3080. Should pop to the top. If you're browsing the store, order by new and again it will be at the top.
Just been contacted by said store and apparently the block I ordered is not for the F/E card. Even though on receipt And on the website it says f/e block. I bought the bundle with the digital display. Also the digital display is not compatible with f/e blocks. On there site the right one is called 3090 original version.
Did you message them to ask or what promoted them to send you that message? What is the first letter of the seller?
They contacted me via the app.asking me confirm the graphics card the water block is being used on. Lucky I downloaded it. If you bought from the same place mine was cheaper than yours by £10 and that was with shipping from China as well. Bought from the official from a company starting with A
They contacted me via the app.asking me confirm the graphics card the water block is being used on. Lucky I downloaded it. If you bought from the same place mine was cheaper than yours by £10 and that was with shipping from China as well. A is the letter
A***** M** S****?
I messaged them just now and they have responded back within 5 minutes to say:
This is a screenshot I have taken from a post on Wccftech (I know, take with a massive pinch of salt!):
So the question would appear to be - which AIB manufacturers might be using this reference board?
Gigabyte Windforce and Eagle are... but Gigabyte do roll out second versions were they switch components/make it cheaper and better down the line .
Ah okay in that case we should be expecting something at the end of this week then. Even better! Thanks for the news
This is good to know, making EVGA cards more of an attractive proposition. Just comes down to pricing, i know EVGA is usually more expensive than most.
they started to change stance a liittle with mining boom. know tthey gott picky with 2nd hand warranty transfers. Now if RTX3000 turns out to be better then RX5700 XT for latest boom.. they might updatee
Well doesn't matter now lol, ordered a custom 12pin cable so the FE will be the card im getting. I hope these stickers are not on the FE cards as well...
