I was flying the blimb then trying to shoot rockets at it, the rockets were coming back, so I batted them away.
I assume the black circles at the very far left and right of your peripheral vision is perfectly normal?
It was the same on the PSVR. Assume it's just the limitations of the current technology.
You soon forget after a while.
The reviews were all saying that the onboard audio was crap, but I think it's pretty good. Have to say, all in all, for £300 this is absolutely brilliant.
I could quite happily mess about playing the free stuff for a while before buying any games.
Wasn't very good with the bat and ball lol although I did spend a worryingly long amount of time punching the hovering ball thingy.
. Had great fun shooting rockets off, and watching them flying around and trying to throw cubes at them as they came back.I assume the black circles at the very far left and right of your peripheral vision is perfectly normal?
I noticed this too on the first boot up. I think the FOV is slightly lower than the original quest but certainly the screen clarity is loads better.
The black levels are on a par with my Index, which again is acceptable.
Am I right in thinking I don't need Virtual Desktop if I'm just connecting my headset to the PC via USB? (3.1)
Great, thanks. Got a Wifi 6 router on its way, so I will give both a go eventually. What's the difference between the VD app in Steam and the one in the Oculus store? Presumably, the only one I'll need is in the Oculus store?
You need the one in the oculus store.
To be specific you need the one in the Quest section of the Oculus store.
You'll also need to setup side loading by creating a developer account and installing Sidequest.
https://uploadvr.com/sideloading-quest-how-to/
