- 19 Jan 2007
- Up a Tree
Is it better to use the stock AM4 mounting or the offset mounting?Swapped mounting round so the plate is in its stock configuration.
Set voltages and frequencies manually.
Normal position was 4-5C warmer in the same stress tests at the same conditions. There was also a greater different in the temp between the CCX's with 7-9C for stock and 4-5C for the ryzen 3000 placement.
Ryzen 3900x on a B550 tomahawk mobo.
in the ryzen 3000 position the TP looks like this
stock position it fits the IHS corner to corner
Seems the offset mounting is running cooler but has worse coverage, is that right?
