How would people say my temps are for my 5800x I ordered from OCUK and use it with a Asus strix x570-e and Corsair hydro icue h150i pro xt 360mm
In BIOs the CPU temp stays around 50degrees and when I check in HWmonitor in a fresh windows install its hovering around 45-50%
I performed a few Cinebench R32 benchmarks and it got up to 87 degrees and stayed there and I was seeing 4.9 single core clock speed and 4.5 all clock speeds.
So I'm just not sure if its just these AMD CPUs run hotter or mine is running hot.
Hopefully tomorrow my new thermal paste comes in so I will replace the stock AIO with grizzly, but I cant see this making much difference.
Lots of real cores for testing multiple instances. 16 cores even better but cost getting a bit high. 12 is a sweet spot for me. YMMV
