*** AMD "Navi 3X" (RDNA 3 discussion thread) ***
Permabanned
OP
2 Sep 2017
The 6600XT isn't a 4K chip though, even if it had a 512 bit bus it wouldn't give 4K playable framerates (not without dropping settings) it just lacks the shader cores to drive all those post processing effects that are important at 4K.
It is a bad graphics card for any resolution.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
15 Oct 2019
Uk
There's no way AMD is going to give the 7600XT performance on a level with a 6900XT considering the current 6600XT only got the performance of a 5700XT while also costing more.
My guess is that this will be the 7700XT and the 7600XT performance will land Between a 6700XT and 6800 non XT.
Permabanned
OP
2 Sep 2017
Little bit dramatic.
You wouldn't be using this card for 4k, like you wouldn't be using a 3060 for 4k.
The 6600XT easily beats out the 3060 at 1080p
But not for 600 euros. Never!
This card should cost 150 euros, and they charge 4 times more! The scalpers!
30 Jan 2007
PA, USA (Orig UK)
Well yes, the issue is cost not performance. Performance is between a 2070 super/3060 and a 2080/3060ti.
I would say the card 'should' be sold for $279 to $329. MSRP is what $379? Street price is $400 to $600 dollars here.
References:
580 was $229 on release
1060 was $250 on release
RTX 2060 was $349 on release (which was kinda where prices were ramping up by Nvidia taking the royal P with things.).
15 Oct 2019
Uk
References:
The lack of a decent amount of cache and low bus has potential to be an issue for future games though, take farcry 6 for example where it's barely faster than a 5600XT.
9 Nov 2009
Planet Earth
References:
Its a 128 bit memory controller dGPU,and only has 32MB of Infinity Cache(AMD themselves indicated that 64MB is ideal for 1080p),so it realistically should have been priced at most around $279 for the base models,which was the RX5600XT price.
That would at least yield around a 33% generation on generation improvement. You should ideally targetting at least around 30% to 40% performance improvements per generation. For example the RTX3060TI was around a 36% improvement over the RTX2060 Super.
30 Jan 2007
PA, USA (Orig UK)
I was accounting for inflation. Cheaper would be better, and it is clear it is a VERYYYYY heavily budget made card. Stripping down to 8 lanes and 128bit is the extreme clear indication of this.
Permabanned
OP
2 Sep 2017
But the other 6 series cards are just as bad if not worse.
MSRP looks to be 369 euros, so the cheapest one is not quite double the cost.
Someone should give data about how many consumers who had been previously considered budget conscious and enthusiasts can now buy with these scalper prices.
This is a card that should be entry level, but is charged with the enthusiast level pricings.
Permabanned
OP
2 Sep 2017
All I know is, both Nvidia and AMD must be extremely happy right now.
Like torturing someone and be happy for your crime. Very low ethics and mindset. It betrays the whole gaming community.
The gamers will return "the favour" multiple times. Resulting in potential heavy sanctions for the criminals.
