Another ridiculous measure by MS - even if well intended - warning you is one thing hard blocking is another. There are a couple of ways around (allowing apps from anywhere doesn't work for every situation) it but obviously updating is better if you can but some people do have good reasons for staying on an older version i.e. needing specific hardware compatibility for legacy stuff, etc.
I have no idea why MS don't do the intelligent thing and properly separate out security, driver/software and feature updates so people can properly update things as makes most sense for their use and put some focus into the deployment of security updates to make them as seamless as possible - see as security is oh such a big deal for them.............
They could learn a thing from Linux or two, never had any issues with updates on Linux, however on Win10 I've had " Windows Update Error 0x800070002" twice. I always have this link https://recoverit.wondershare.com/p...bcZLQa_Nl-8aSBhoo2pMFb2QFcnber3RoCI98QAvD_BwE for fixes (method 4 always best in my case), it always works for me, but the average user would probably not know what to do or be bothered to try and fix it, they expect Windows to update and not cause issues or problems.
Seems like they are getting lazy with their updates, ie bad programming or testing.
memory leak in DWM unless I disable the iGPU and force it to always use the nVidia GPU, nVidia driver crashes and recovers if the laptop turns off the display (not going into sleep) also unless I disable the iGPU - seems to be a Windows 10 issue not nVidia drivers. MS blames Intel, Intel blames MS but largely seems to be a Windows 10 issue.
