Indeed, iPhone 12 (Pro Max) and Safari. Latest version of iOS 15.5.
Can you install chrome or similar and see if its an issue?
Highlight the text and select reply, see the attachment. The old forum worked the same way.What if I wanted to quote a few paragraphs of text?
I'm not seeing that option in Firefox. I don't use the forums on my mobile, so perhaps the two are different?Highlight the text and select reply, see the attachment. The old forum worked the same way.
If you want to add more paragraphs, select them and either use multi quote or you can highlight and click reply and they all get added to your reply.
You don't see the standard reply button in bottom right?I'm not seeing that option in Firefox. I don't use the forums on my mobile, so perhaps the two are different?
I don’t use Firefox at all but on all the other browsers I’ve used, desktop or mobile, the multi and reply options are there when I highlight text.I'm not seeing that option in Firefox. I don't use the forums on my mobile, so perhaps the two are different?
No, I just use OcUK's own blue theme, completely unmodified apart from a few rules in uBlock Origin to make more space. Even with uBo disable, nothing changes.You don't see the standard reply button in bottom right?
Are you running custom themes?
This is all I get:I don’t use Firefox at all but on all the other browsers I’ve used, desktop or mobile, the multi and reply options are there when I highlight text.
	You need to highlight the text of a different post - any other text (including the text of a quote within a post) doesn't get the popup.No, I just use OcUK's own blue theme, completely unmodified apart from a few rules in uBlock Origin to make more space. Even with uBo disable, nothing changes.
This is all I get:
What if you select some text in a post, not in the reply.This is all I get:
Okay that worked, I see what you mean now. But what I meant earlier was, what if I wanted wanted to copy and paste some text and insert it as a quote? There isn't a quote button.What if you select some text in a post, not in the reply.
We’ve just shown you.But what I meant earlier was, what if I wanted wanted to copy and paste some text and insert it as a quote?
You mean from somewhere else - so not quoting a post but say a document or something?Okay that worked, I see what you mean now. But what I meant earlier was, what if I wanted wanted to copy and paste some text and insert it as a quote? There isn't a quote button.
) gives you an empty quote box you can type or paste into.Some text here
Ahh, that’s possible.I think he means text from another site?
Sure, I’ve just downloaded the Chrome app and will see how that goes for the next day or so. ThanksCan you install chrome or similar and see if its an issue?
That's right. Sometimes I might want to copy and paste text, say from a BBC article. I usually copy and paste it, to retain the formatting, otherwise I'll just remove the formatting if it messes fonts up, etc.I think he means text from another site?
I'm not seeing a quote icon when I click the three dots.Ahh, that’s possible.
Paste it into the reply box, highlight it, hit the three dots and select the quote icon.
	isnt it literally 2 icons to the left of the 3 dots?I'm not seeing a quote icon when I click the three dots.
Okay I am a bit confused now. When I tried copying and pasting a few lines of text from Notepad and clicked that button, they were all quoted in one box.isnt it literally 2 icons to the left of the 3 dots?
This is line 1.
This is line 2.
This is line 1.
This is line 2.
There you go.The hot spell will give way to thundery downpours over the weekend, but next week should bring some sunshine and fine weather for most of us. Chris Fawkes has the details.
I’ve given it a go and gone to video/link heavy threads a few times and general browsing and the issue doesn’t seem to occur when using the Chrome app…Can you install chrome or similar and see if its an issue?
Problem solvedI’ve given it a go and gone to video/link heavy threads a few times and general browsing and the issue doesn’t seem to occur when using the Chrome app…
 I will take a look, but this is likely an apple/safari issue so unlikely something I can roll a fix out for.
