- 10 Nov 2006
- Lincolnshire
Just picked one of these up, what settings should I be using for best performance/optimisation?
I wouldn’t worry about getting the hole for the cables dead centre. The panel is big enough that you can get it in the approximate location (take the overall width and drill halfway across).On the rear of the screen, what is the distance from centre of screen to right hand edge where the connections start ? I want to create a hole in my wall so I can feed my cables through to the inputs. Also what is the distance from left side and bottom edge to where the little panel is for the power cable ?
Thanks a lot
I went from a samsung g7 32" odyssey and yeah at first it was like the screen was warped but soon looked fine. I have had mine since April and not had any issues and love the screen, for productivity and gaming, very happy with my purchaseI paid £1043 with 5 years warranty, well worth it imo, paid 1700 for my 38GL950B and doesn't have half the features.
Coming come a concave (curved) screen to a flat screen it feels convex, is this normal?
Does your warranty include burn in? As a lot don’t include it or include it in the standard warranty.I paid £1043 with 5 years warranty, well worth it imo, paid 1700 for my 38GL950B and doesn't have half the features.
Coming from a concave (curved) screen to a flat screen it feels convex, is this normal?
Don't know how do I check, it's from the only highstreet electronic retailer?Does your warranty include burn in? As a lot don’t include it or include it in the standard warranty.
Is there a pdf or link to the terms? As when I checked two other big retailers in the UK both their standard ones did not cover it and only one paid did. And the one that did wanted an extra £150 which was annoying. So it negated any saving that the discount I saw had.Don't know how do I check, it's from the only highstreet electronic retailer?
should have gone to spec saversI paid £1043 with 5 years warranty, well worth it imo, paid 1700 for my 38GL950B and doesn't have half the features.
I had one from the high street retailer with its own 5 year warranty. It hit 4years 11 months and then had issues where by screen burn was one of them, the screen was written off and a fair value that enabled me to buy a replacement was issued. I then bought another with the same warranty. Can’t fault it really, the down time however at near a month was a bit much..Don't know how do I check, it's from the only highstreet electronic retailer?
