After you upgraded to ABVC.4 did you do the cellular module update? It mentions in the modem upgrade SOP guide "Upgrade the router firmware to the suitable version first and then upgrade the module firmware."
D’oh!
That's cool - good to hear!Firmware & modem upgraded to latest versions, download speeds hovering around 450mb with upload around 120mb
Thanks for your help
I have the new ZTE (mc801) router, nice bit of kit but be very careful plugging in external Ariel’s as the ports are really weak. I had one snap off inside while plugging my external in and I was being pretty gentle.Looking at trying the three 5G deal see what speeds are like round my way. Would like to know if anybody has this whats the supplied router like, will it pick up a good signal on its own, whats the WIFI like and is it ok to keep it on for long without having to reboot?.
I believe, but better to check before going ahead, you get 14 day cooling off period. So if you ordered and no good and we're within 14 days you can still cancel. I've done that before.Looking at buying a flat and would have to go with either EE or Vodafone with the 5G home broadband, just don't trust the coverage checker enough and don't want to get one and find out the coverage is poor inside the flat, I jump on the Xbox now and then with mattress and have a few smart home bits, iPads, phones but just not sure thismeets the criteria I need, I'd settle for 150mbps but not sure I'd get it, wonder if they'd allow you to return the item and cancel the contract if not good signal.
Is that the same for 4g?For anyone struggling with 5G signals with the antenna placed in a window, move it away from the window as many types of glass will reflect the 5G signal depending what polarisation it hits the windows at.
I don’t know. I was in at a testing centre this morning near Bedford about WiFi but they also showed me a test setup for 5G and the lady running the testing said 100% don’t put it in the window because of reflections.Is that the same for 4g?
I've tried this. Near the windows is my best location and I've not moved it from original location where I had great speeds.For anyone struggling with 5G signals with the antenna placed in a window, move it away from the window as many types of glass will reflect the 5G signal depending what polarisation it hits the windows at.
They do and they are commonly used. If you live in rented accommodation or you’re drillophobic then sometimes they’re not an option.Why don't they make an all weather antenna to put on your roof or windowsills?
