Im still sat here umming and ahhhing over a C1 55" as an upgrade for my C6V.....
If it was under 1k i would bite on it i think, Anyone suspect that will happen anytime soon?
Tanks bud![]()
LG OLED55C16LA 55” C1 OLED 4K Smart TV Black
Important InformationFree 5 Year WarrantyColourBlackScreen Size (inches)55SmartYes4K UHDYesOLEDYesManufacturer Guarantee1 year EAN8806091154866www.smithstv.co.uk
Tanks bud
Are they reputable though? I did find this, but have always bought "expensive" things from JLP or Richer sounds just to be a bit safer.
Yeah i was just reading the sameHaven't bought a TV from them, but have other items and seem fine. Trust pilot seems okay as well:
Smiths TV is rated "Excellent" with 4.7 / 5 on Trustpilot
Do you agree with Smiths TV's TrustScore? Voice your opinion today and hear what 2,318 customers have already said.uk.trustpilot.com
Does anyone use the (what I presume to be) IR receiver.. The wire with the two black hemisphere things on it?
The remote seems to work fine without it.. Was just wondering what the point of it is?
Is this a G series? They come with an IR emitter I believe...Does anyone use the (what I presume to be) IR receiver.. The wire with the two black hemisphere things on it?
In terms of general IR, yes there's still a receiver - it's used for ordinary IR remotes and the power button on the Magic Remote. The Magic Remote then switches to RF signals if it is paired, if it's not paired then it sends signals over IR until it pairs.
What I'm saying is I think it's an output not an inputaH OK, mines a C2 42". So I guess it's just a legacy device/thing then? I'm not entirely sure what you mean lol!
It looks like this:
I ended up getting my local RS to price match the Smiths online link, so might be worth a go.Hi all, I am looking at a C1 as well to replace my ageing but still great Sony 4K LED. I mainly use it for PS5 for gaming and movies. Would I be correct in saying that the linked above is the one to go for?
With my branch you can order over the phone and have a home delivery, at least thats what they offered for me at no extra charge!Might be struggling with local RS as its over in Nottingham and my car is hybrid so the back seat doesn't fold down. I can borrow the works van but only for local runs so if i get it delivered to work i can run it home. I have thought about the C2 but from reviews it doesnt look like a massive upgrade (Altho it does weigh significantly less and the processor is a bit better) for the money. I have also seen from reviews and setup videos the C2 doesnt look like it has a option that the C1 (Black Frame Insertion) that gives the PS5 a better fluidity. Oh and about £1k is going to be my limit really.
