My M27Q is nowhere close to 1000 nits but only 440 and even that with HDR is quite eye searing.
Tired eyes I guess
I have not had any issues with the HDR in games I play at 1000 nits. Plus you can adjust it in game with quite a few games
Tired eyes I guess
I have not had any issues with the HDR in games I play at 1000 nits. Plus you can adjust it in game with quite a few games![]()
Seen it that many times that in my mind, that gif is how TNA looks in real life!
So, if someone wanted to, they could just keep adding mods until they filled up whatever size buffer?I do have lots of 3rd party add one in my MSFS such as airplanes, airports and scenery, vanilla does run fine within the limits of 10GB but it easily exceeds 10GB when you run a more graphically intense version.
Well it’s not modding. I wouldn’t even know where to start with that. It’s simply dlc from the in game store which lots of people buy to enhance their experience. I also wouldn’t go by old videos of MSFS as it’s system requirements have increased rapidly over its 2 years and are set to increase again this week when SU10 comes out. Already on dx11, as per usual dx12 sucks!So that fits into the criteria we have covered where if modding, you can push vram like I did in cp 2077 when using several 4-8k texture packs
TBF though based on the above videos, I doubt even a 3090/6900xt would give you a great experience given their fps on the "vanilla" version are also in the 30/40/50s depending on where you are in the world, they would maybe allow higher res. packs with a smoother frame latency but I imagine their performance would also be hit over the "vanilla" version thus requiring settings being lowered or/and higher presets of dlss to be used at higher resolutions, which in return will also lower vram usage.
Not sure what settings you use but if you haven't already, try dx 11 if you are using dx 12.
Debunked?Well it’s not modding.
Both feet?So, if someone wanted to, they could just keep adding mods until they filled up whatever size buffer?
