- 14 Aug 2018
It sounds like you've been taken in by Intel terminology as you are not comparing like with like. The 13900k has 8 Performance cores and 16 Efficiency cores.....13900k should smash the 7950x in MT loads due to having 24 core vs 16 on the AMD chip. Plus the intel is cheaper too !
So it is misguided to say that because 24 is bigger than 16 then the 13900k must be WAY better, when in reality due to the type of 'cores' I suspect those people doing fully multi-threaded workloads will be better served with the 7950x.
