- 28 Jun 2022
- United States
It will be slightly higher than 1% in real reviews because he ran both 12 and 13 gen overclocked, 13 gen is just a clocked up 12 gen, i don't know what else anyone was expecting? That has been Intel's MO for more than a decade, you would think people would have learned that by now.
You can get the same gaming results from 12 gen, absolutely no point in anyone on 12 gen to upgrade.
Well that makes sense given IPC has almost no increase. I wonder if there is even a regression in some workloads as per Intel's own slide a couple of games performed better with 12900K despite 13900K having like 300-400MHz higher P core clock.
Though if IPC is the same and P cores can clock higher with much more thermal headroom to achieve like 300 to 400MHz faster on P cores without any extra heat or power consumption. I would think higher clocks should boost gaming performance at same IPC especially with RTX 4090 which has a CPU bottleneck at 1440P??
