There is always scope for Intel to start sponsoring some games to use the E-cores for certain tasks. I agree more P cores would be nice,but the issue is that AMD pricing is off for the Ryzen 5 and Ryzen 7 CPUs,so AMD does not really have a core advantage overall.There's a misconception about ecores hurting gaming and this was mainly from those who bought ADL and wanted to stick it on Windows 10 despite warnings. It's also an easy distraction by the people who haven't had direct expereince with the platform but tend to post the most here.
As shown here: https://www.computerbase.de/2022-10...bschnitt_vorteil_durch_mehr_ecores_in_spielen There's no detriment to gaming from the ecores. Naturally, they add a lot for producvity and also are good at handling backgroup tasks which is often not considered in reviews. In some games, they will add some performance as well. As W11 has evolved, ecore handling has improved greatly. Would I take more Pcores over Ecores? ofcourse but they're not some performance killing evil. Also the ring clock bug is fixed on RPL so ring can now scale with ecores enabled which wasn't the case on adl
As I menionted in the other thread, we're seeing pretty much any 13600k land around 5.5 all core with some voltage and llc tuning so there's notable headroom on top of the already great performance.
but whos buying the 13600k ? cant imagine many are buying it for productivity in that chart looks like dropping 4 e cores doesnt effect much in performance in gaming and still be ahead for MT imagine 6p-4e which would lower power and if closer priced to the 7600k , would wipe the floor budget system for gaming and on DDR4
it's not the additional E-Cores in the Core i5 that push the CPU up a notch either
www.techspot.com
www.techspot.com
I also posted this:@CAT-THE-FIFTH
Timely video here. You can see the value of the 13600k and this further reduces platform costs by re using DDR4 which most DIY enthusiasts will be on. Then you can pick up a z690 ProA or PrimeP board to make the platform cost even cheaper. For a mid range buyer, that's been my recommendation since before they were officially launched (with having access to the data for some time already) and that's not changed since.
MSI Pro Z690-A DDR4 - Intel Z690 DDR4 ATX Motherboard
Order MSI Pro Z690-A DDR4 - Intel Z690 DDR4 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
This board will handle it without any concerns.
www.techspot.com
@CAT-THE-FIFTH no one is buying an i5 for productivity, you're barking up the wrong tree.
Now let's look at productivity benchmarks agains a Ryzen 7 7700X. Puget Systems is a good start:
13th Gen Intel Core Processors Content Creation Review
Following AMDs recent release of their Ryzen 7000 Series desktop processors, Intel is fighting back with their own launch of the Core 13th Gen processors (code named "Raptor Lake"). Unlike AMD's launch which moved to a new socket and added support for DDR5, the 13th Gen CPUs are a drop-in...www.pugetsystems.com
I only posted some of the benchmarks,but in the Puget Systems benchmarks,consistently the Core i5 13600K beats the Ryzen 5 7600X and Ryzen 7 7700X in all the image editing/video encoding scores. It even beats a Ryzen 9 5900X and Ryzen 9 5950X in many cases too,including video editing! In 3D rendering it beats a Ryzen 7 7700X and the Ryzen 9 5900X.
You can see the same here:
Test • Intel Core i9-13900K, Core i7-13700K, Core i5-13600K & Z790
Les Core i9-13900K & 13600K ainsi que leur chipset compagnon Z790 passent à la moulinette : comparaison avec les précédentes générations de processeurs sur des jeux, encodage, traitement d'image et vidéo, rendu 3D, compression, encryptage, compilation et divers benchmarks synthétiques et...www.comptoir-hardware.com
Even here,in a mix of image editing,video encoding and rendering benchmarks the Core i5 13600K is beating a Ryzen 5 7600X,Ryzen 7 7700X and Ryzen 9 5900X by decent amounts.
Then there is the DF review:
Intel Core i9 13900K and Core i5 13600K review: an effective redoubt against AMD's Ryzen 7000 advances
Digital Foundry tests the Intel Core i9 13900K and Core i5 13600K, two Raptor Lake processors that offer more cores, higher clocks and winning results.www.eurogamer.net
In their gaming results the Ryzen 5 7600X is beaten,and again it's massively beaten by the Core i5 13600K in non-gaming results. Even the Ryzen 9 5950X is only slightly ahead in their video encoding results!
Guru3D shows the same trends:
Intel Core i5-13600K review
Okay, so you really need to check out this Raptor Lake processor; the Core i5 13600K has six performance cores and eight energy-efficient ones. Meaning you'll have plenty of multi-threaded performanc... Performance - Content Creation Blender / Cinebench R23www.guru3d.com
They run a lot of 3D renderers,and in all of them the Core i5 13600K is faster than a Ryzen 7 7700X. It seems to trade blows with a Ryzen 9 5900X,which is over £400.
Then look at TPU:
Intel Core i5-13600K Review - Best Gaming CPU
Core i5-13600K is a gamer's dream! The new processor achieves gaming numbers that match the best AMD Zen 4 offerings, at a much more competitive $320 price point. Our review also shows that 13600K can shine in applications, beating the much higher positioned Core i7-12700K.www.techpowerup.com
Consistently the Core i5 13600K seems to trade blows or is faster in most benchmarks than the Ryzen 7 7700X and Ryzen 9 5900X.
People might want to mock the E cores,but they since they are Skylake level,they are helping boost performance in non-gaming scenarios a lot. Overclock3D tests performance with DDR4:
Intel 13600K and 13900K DDR4 vs DDR5 Showdown - OC3D
Video Encoding If you thought 3D rendering didn’t have much to differentiate the two setups then the video encoding is so close it might as well be the same. Sometimes no result is still a result.www.overclock3d.net
At most in their gaming and non-gaming tests you are loosing about 10% performance. So that means even for many productivity benchmarks,the Core i5 13600K is still going to look really solid.
The reality is the Core i5 13600K is a productivity monster too,and the Core i5 13600KF is only £30 more than a Ryzen 5 7600X and significantly cheaper than either a Ryzen 7 7700X or Ryzen 9 5900X or Ryzen 9 5950X. Plus you can use a DDR4 motherboard too(even if it costs you some extra performance).
Plus you could argue the Core i5 13600K draws more power in productivity benchmarks than a Ryzen 5 7600X,but the extra speed help's its effciency.
But we also know in gaming capping the CPUs to lower TDPs,probably won't affect performance that much in gaming:
Intel Core i9-13900K vs. AMD Ryzen 9 7950X at 125W and 65W | Club386
Prefer to keep temperature and power consumption down to lower levels this winter? Here's what happens when the best CPUs are scaled back.www.club386.com
You are also looking at the best productivity CPU under £400~£450:
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
Currently in the top 12 US.
1, Ryzen 5800X
2, Ryzen 5600G
3, Ryzen 5600X
4, Ryzen 5900X
5, Intel 12700K
6, Intel 12900K
7, Intel 13900K
8, Intel 12600K
9, Ryzen 5800X3D
10, Ryzen 7950X
11, Ryzen 5700G
12, Ryzen 5600
The rest of the new chips.
22, Ryzen 7700X
23, Intel 13700K
25, Ryzen 7600X
26, Ryzen 7900X
46, Intel 13600KF
52, Intel 13700KF
56, Intel 13900KF
Notice how the 7700X is outselling the 13700K/F?
The 7600X outselling the 13600KF? the 13600K didn't even make it on the chart.
Because for what people want them for they are cheaper.
They are all too expensive CAT, you're wasting your time trying to justify over priced Intel CPU's, its not going to make a difference to AMD's over priced CPU's.
Overclock3D did a quick set of tests including non-gaming applications:Is there any good non-youtube review of Raptor Lake on DDR4 VS DDR5?
www.techspot.com
Might I take from it that if you're gaming with DDR4 it's better to stick with 12th gen or am I misreading?Overclock3D did a quick set of tests including non-gaming applications:
Introduction Any new technology is going to come with a hefty adoption cost, and the Z790 and Intel 13th Generation of processors is no exception. However, during our time with the various motherboards we had on hand we noted that a few of them support DDR4 rather than demand you invest in DDR5...www.overclock3d.net
Techspot(website version of Hardware Unboxed) tested DDR4 too but only with games:
Intel Core i9-13900K Review: Hot and Hungry
Hot of the heels of AMD's Zen 4 series launch, here comes Intel with their highly anticipated 13th-gen Core series, codenamed Raptor Lake. Today we're reviewing the...www.techspot.com
Looks about a 10% performance reduction at worst.
That overclock3d.net DDR4 review is pretty poorly formatted though - and has charts which don't start at zero, which is always a sign of amateur or marketeer IMO. Pity no decent site did DDR4 testing.
DDR4 vs DDR5 - i5 13600k vs i9 13900K
Thankfully with Z790 we still have the option to run DDR4 or DDR5 so we have tested the i5 13600K and the i9 13900K with both DDR4 and DDR5 to see what perfo...www.youtube.com
lmao I don't even know what to say here. He's running DDR4 in G2. I can't imagine how bad the rest of the setup is. What a waste of a nice kit.
