- 27 Jan 2009
- United Kingdom
It's not even a disater it's just priced crap in the UK
Lets say they are both virtually the same in Rasta (which they are not too far off) so lets put it down to RT/Features
In the US it's $1200 vs $1000 you are spending 20% more for that RT performance over the 7900xtx
In the USA the XTX is a good value card, you if you don't care for RT you get the same performance for 200 less, and if you want better RT you have to spend 20% more to get it.
The problem is the UK prices
£1050 vs £1150 you are paying just under 10% more for the 4080 so to get that extra performance in unique features. 10% more isn't that bad... you would normally expect to spend 10% more on an AIB card so the 4080 becomes more of an option.
The issue is the value difference between the 7900xtx and the 4080 is halved in the UK making the 7900xtx a harder choice.
