I'm betting £549, just slightly better than the outgoing 6950XT at £630ish. At that I might bite, I'd like a 7900XT but at £800+ I'm having a hard time justifying that.And priced to not sell, pushing everyone into either a 4070 or 4070ti![]()
You must be smoking Jenen's "pipe" lol...The 4060 8GB is going to be a right **** show launch. Honestly think Nvidia are happy taking the L with ADA after having so much crypto ampere inventory left over to sell. Nvidia will be back on form with the next gen, 4090 performance for $699.
If it is that 'low' on launch then you can be damn sure it'll be a limited time 'AMD supported' price and will shoot up after a few days of sales. They love doing that dodgy ****.I'm betting £549
That will beat the 4070 at raster and have more memory (which is increasingly becoming something buyers are concerned about) so I'm betting £600, despite Nvidia having stronger value-adds.I'm betting £549, just slightly better than the outgoing 6950XT at £630ish. At that I might bite, I'd like a 7900XT but at £800+ I'm having a hard time justifying that.
You could be right, I'm an optimistThat will beat the 4070 at raster and have more memory (which is increasingly becoming something buyers are concerned about) so I'm betting £600, despite Nvidia having stronger value-adds.
I saw this posted on TPU:
*snipped image to save space*
Unlikely. 7900XT max will fall to £750 and stay there. 20gb vram 320bit bus and performance between a 4070ti/3090ti and 4080 and on par when overclocked with the 4080 at rasterisation. RT perf would be at 3090ti level.I kind of think AMD deserves some credit for the simplicity of their line-ups. It's generally fairly predictable what you are going to get as a result.
I think the RX 7900 XT will fall to around £700, and the Navi31 card below it (still speculation at this point), could be sold for ~£600.
Navi32 will be the sub £500 more affordable segment, likely priced similarly to Navi22.
Navi33 is built on 6nm, so I don't think it will be much of an improvement vs Navi 23, nor cheaper.
Have to wait and see, but I will use what little hope I have left that it is not.And priced to not sell, pushing everyone into either a 4070 or 4070ti![]()
I might stretch to that, whatever they do they need to hurry up! Whether they do anything before Computex I doubt it. 7800XT announced there...?Unlikely. 7900XT max will fall to £750 and stay there. 20gb vram 320bit bus and performance between a 4070ti/3090ti and 4080 and on par when overclocked with the 4080 at rasterisation. RT perf would be at 3090ti level.
At £750 I would seriously consider a 7900XT, should get 5-6 years use, out of it, though would still wait on the 7800XT as it suits my needs more.Unlikely. 7900XT max will fall to £750 and stay there. 20gb vram 320bit bus and performance between a 4070ti/3090ti and 4080 and on par when overclocked with the 4080 at rasterisation. RT perf would be at 3090ti level.
Computex is most likely and can show up Jenson in person, "look more VRAM and lower price".I might stretch to that, whatever they do they need to hurry up! Whether they do anything before Computex I doubt it. 7800XT announced there...?
Jeez the 4060Ti will end up slightly below 25% of the overall AD102 core count...
Could it nbe part of cunning plan to make us all but 4090's or 7900XTX's with there 24GB VRAM as only way to "future proof".Buying a 12 or even! 16gb card now is a bit worrisome with the future of console ports. I’d always go for as much vram as possibly my budget allows and if needed push above it by £100.
So does this mean the 4070 is more comparable to the xx60 series in previous generations but double the price ?I saw this posted on TPU:
Yep.So does this mean the 4070 is more comparable to the xx60 series in previous generations but double the price ?
