Caporegime
- 7 Apr 2008
- Lorville - Hurston
NoDoes Currys have good return policy in case of problems etc?
100% notDoes Currys have good return policy in case of problems etc?
So no 14 days cooling off period when buying online?100% not
Just the normal UK 12 months faulty returns policy.
If you are looking for the "try before you buy" 14 day period. Not going to happen, unless its unopened or proven as faulty.
I keep setting it sat on a little white plastic square so you can play hands free. Is this included with it?
Are guys sure about this?
From their site under the Ally listing.
Returns and refunds
If you purchased online and you have changed your mind you can return your items within 30 days even if you have opened it for inspection. It must be returned as new and where possible, in its original packaging.
Yes but read what I pasted above. If that is on their website then they cannot renege on that surely?If your item develops a fault we will offer either a repair, exchange or refund if the fault occurs within 30 days of purchase (or delivery or installation). If the fault with your product occurs within its guarantee period (normally 12 months from delivery) we will offer you a prompt repair service. In all cases we reserve the right to inspect the product and verify the fault.
Say what now? So it develops a fault and they can say "we're no inspecting the fault, gooday sir"
Go ahead and buy from curry's.Yes but read what I pasted above. If that is on their website then they cannot renege on that surely?
Are you speaking from a bad experience G2?
Returns and refunds
It seems like boilerplate warranty terms.If your item develops a fault we will offer either a repair, exchange or refund if the fault occurs within 30 days of purchase (or delivery or installation). If the fault with your product occurs within its guarantee period (normally 12 months from delivery) we will offer you a prompt repair service. In all cases we reserve the right to inspect the product and verify the fault.
Returns and refunds
This if true at least sounds like trying to do the right thing with it.Summary nicked from Neogaf thread from ASUS QA on YouTube..
These were the most interesting updates:
The sticky button issue has been fixed
They are still optimizing performance and expect gains at lower wattages
You can stream and capture with it easily using an external USB type C hub with an HDMI out or even via WIFI
There will be third-party accessories
You can install any OS you want on the device, including Steam OS, though they won't be able to support it and it will be up to Valve. Dual booting should work, but they don't know how it works (these guys aren't tech people)
If you reinstall Windows, you'll get all the drivers and software (Armory Crate for the ROG Ally) from ASUS
They plan to give it robust support and plan to support it for years to come
Bios uses secure boot, can be turned off. Has plenty of features.
Can upgrade the SSD easily! Very accessible, very easy to reach! There will be a teardown video soon.
Gyro support at the moment is not built into the software, needs to be supported by the game by they're working on it to make it global
Possible to disable multi-threading and cores (not at the moment, they're working on it)
Will support VR
Support up to 4 controllers
Has game profiles, and you can customize performance individually
Armory Crate can be disabled at boot if you wish
The screen can't be set at 40hz but can be run at 40hz with frame limiting (and it has VRR)
They are taking the feedback from the reviews very seriously and improvements are coming.
From what I read, armory crate is janky. Is it a place for quick settings?
Armoury crate is utterly garbage.From what I read, armory crate is janky. Is it a place for quick settings?
