Caporegime
- 18 Oct 2002
Rumours were for the panel to be available later this year, can't see it myself (maybe early next).We got any clue when the G8 gen 2 OLED 21:9 version might come out?
What arms are people mounting this on if any? I impulse bought one of these last night for an insanely cheap price as they seem to allow stacking discount codes..
I currently have a 34 inch ultrawide on an ergotron lx and Im wondering if it will hold the weight of this.
Good luck doing that if they've fulfilled part of the order.Let's not get ahead of ourselves, Samsung could cancel these orders...especially my one at £535
I plan to use the same mount which has a max weight of 11.3KG. The G9 comes in at 9.2Kg without stand.
How do you know if part of your order has been fulfilled or not? mine after 2 codes was £1399 if my order gets canceled i'll be p*****!
Phew thanks you had me worried there haha***************
They've now unlisted the monitor due to people trying to get the mega discounts, I expect orders will be cancelled unless part of your order has already been fulfilled.
Or they'll sell them to the lucky few who pounced and the discount stacking will now be patched.
It’s not delisted, its just out of stock which is what happened when they sold out of the first batch.
Fair enough, well I've never had it where I search up the monitor and can't find iteven when it's out of stock.
I do kind of hope they cancel it, I have been hovering over the cancel order button but I'm too weak.I'm talking about people who got it at £533-900harder to say if they will.
Because it's out of stockI am now unable to search for the monitor via the Samsung website.
Yeah you're golden mate.I added a tablet to get a further 15% off the monitor, and thats due for delivery tomorrow, hopefully if i get that its a good sign
Yeah I'd return it, Multi view actually works fine for me once you have the scaling set up properly on each device, my issue was you're then sent back to sdr mode and 8 bit 120hz, so I lost a lot of picture quality and vibrance using that set up.I got my monitor on Friday but I may have to return it.
The main issue I have now is there is a vertical line (1 pixel wide) on my screen. It's regardless of whether I use my PC or laptop.
I thought it had picture by picture but it doesn't. Multi-view was a faff to set up but now I've got it to work, I notice that the quality from one side is always worse than the other from my laptop. It may be an issue with the dock or the laptop but the fact I did not have this issue with dual monitors suggests the latter option might be preferable.
Text is actually a lot better than I anticipated which is good and connected to my PC it's great!
