Aye they are ridiculous. I levelled it up to try it out earlier and they are the most broken guns I’ve ever used.FPS doesnt matter. The snakeshot Basilisk seem to be wrecking the game more now that stutter / jusdder / low fps. Everyone we ran into in a duos was using them! 1 shot up close or 2 shot from 20m
Definately the latter, the number of people thinking "shall I just buy these dual basilisk things" is probably quite high.X13 and Basiliskare meta now. No idea why they can't balance things properly. Always ver buffing certaib things. Its maybe intentional to sell more skins i guess.
What AR do you use? I'm back to my trust M4A1 with hightower barrel, commando grip, VLK optic, 60 round and some compensator to get rid of most horizontal recoilIve been using the X13 Auto as my secondary in multiplayer pretty much since the game came out, once id unlocked it obviously.
Its fast, and good for when you dont have time to reload, or if im alive long enough to run out of ammo. The AR that i use for everything seems better in every way though.
I never use it in warzone though. Maybe i should.
Kastov 74uWhat AR do you use? I'm back to my trust M4A1 with hightower barrel, commando grip, VLK optic, 60 round and some compensator to get rid of most horizontal recoil
The 4090 is nice and cool compared to my 3070ti. Is it watercooled or stock cooler?Its got more consistent lately i think but i know what you mean it has spat out some inconsistent result in the past but will now line up very close with a RTSS benchmark running on top of the cod benchmark to compare results ...
I start the RTSS benchmark once you get a game image on screen not while its loading / closing ( high fps at those points ) but seems to line up close enough imo
22-07-2023, 13:55:26 cod.exe benchmark completed, 12152 frames rendered in 58.875 s
Average framerate : 206.4 FPS
Minimum framerate : 128.7 FPS
Maximum framerate : 266.2 FPS
1% low framerate : 125.3 FPS
0.1% low framerate : 47.7 FPS
It is fitted with a EK Active backplate waterblock which is why its nice and cool although this generation the only benefits from watercooling a gpu is cooler temps and a smaller footprint as the block isn't so big , actual performance increase is 0% as the big air coolers are so efficient nowadaysThe 4090 is nice and cool compared to my 3070ti. Is it watercooled or stock cooler?
What use is richochet?
I always seem to do well with the Ak74-U. Might try it again.Kastov 74u
Im still a bit of a noob at online games, and i dont get loads of time to play. So i find a gun i like and stick with it. The game is then consistent. And its just me that isnt.
Ive got three versions of the 74u. The standard one i use most of the time, one ive tweaked for speed and one ive tweaked for distance. I just choose depending on the map.
I use other weapons occasionally, usually to meet the daily challenges but that is my go to.
I did the same in the last game, though i didnt play multiplayer then. Aug and fara83 i think it was
Gimmick really.Pretty much no use at all.
Gimmick really.
Pretty much. Still see levell 500+ wallers every time I play. So much for a kernel level AC.Still boils my urine that a multibillion dollar corporation still doesn’t have a functioning AC.
There is almost certainly a significant number of players cheating on DMZ recently. I started to play Battlefield 2042 again last night after boycotting it from release due to its poor performance, thankfully that so far appears cheat/hack free and runs lovely now its been patched by the developer.I tend to play DMZ mostly these days, and even that is full of wallers who pounce on you like hyenas, with fire shotties, snake shots and akimbo pistols.
The irony is, you engage them at any kind of distance and they are absolute trash.
