Caporegime
- 18 Oct 2002
Yup, a 350W-ish sounds about right. PL will do it on its own but the undervolt will help to go lower when not much load on the system.Okay thanks both
Tried these settings on port royal but it crashed near the end, i can do 965mv though and do the run no problem with a 78% PL. What wattage does yours pull at 78% PL? I'm seeing anywhere between 310-350w.
) and I'm unable to close the side panel currently but an adapter should fix this... But I'm just wondering are there any known issues with these or are they known for failing?
