Caporegime
- 18 Oct 2002
They will do, they provide the adaptor and expect it to be used explicitly.but again I think all the AIB companies would probably do the same.
They're not wrong tbf.they've said its a Customer induced case
Yeah I had to as the adapter is still stuck in the card, when it melted it fused together and now I can't remove itWow, sorry to here that. Did you say you had used the cablemod adapter to asus?
But the same melting has happened with the adapter there provide?They will do, they provide the adaptor and expect it to be used explicitly.
Thats shocking, as long as i've been building my own pc's always used the psu leads to the gpu.Doubtful, provided adaptor only iirc.
Yes, but then it's THEIR adaptor and they accept responsibility. The aftermarket thing is the problem, iirc it was stated that any use of adaptors or cables voids warranty.But the same melting has happened with the adapter there provide?
Warranty not worth the paper it’s written on except if bought direct from Jensen- I’ve had really good experience with RMA 3090 FE about 2-3 times over coil whine, loose heat sinks and overheating. They pay for home pickup and international air freight and return in most cases a new retail gpu.Well had my first response from Asus this morning and it was exactly as I expected, they've said its a Customer induced case and I will be unable to RMA the card, so basically I've got to send it to a 3rd party for repairs and luckily CableMod are going to reimburse me the costs including shipping once it's finished.
Very poor from Asus, but again I think all the AIB companies would probably do the same. I'll be thinking long and hard before I ever buy a Nvidia GPU again, spent the best part of 2 grand on a GPU with a supposed 3 year warranty and now I'm left with this, Crazy
Such a shame that Asus is not taking responsibility for it. At least in this instance cablemod has agreed to replace the card for you otherwise you'd be short £2000.Well had my first response from Asus this morning and it was exactly as I expected, they've said its a Customer induced case and I will be unable to RMA the card, so basically I've got to send it to a 3rd party for repairs and luckily CableMod are going to reimburse me the costs including shipping once it's finished.
I also think in this particular case that the fault lies with Nvidia and their 12-pin connectors.
I've owned past GPUs from Nvidia that lasted for 5+ years before me upgrading and haven't had any issues with them.
Do you know if they be replacing the connector with the newer shorter sense pins?They are not replacing the cards, but repairing them, they are just swapping out the melted connector for a new one, basically the repair also voids the warranty. So the only so called good thing to come out of it is the same card working hopefully again and then hoping no problems happen while in the voided warranty period.
It's all a bit naff to be honest and Nvidia is really to blame for this mess for forcing this connector on their AIB products this time too with the 40 series.. 30 series they were allowed to use the standard 8 pin and 6pin which have worked now for decades. This connector needs dropping and a new one if required or back to the 8pin and 6pin and allow AIBS the options to do that again as they did before with 30 series. The biggest turn off for me with buying a 4090 is the power connector and then no NVLINK but that's another story.
I don't need a fire hazard in my home and also not one on a very expensive bit of hardware that can take out the full pc or the house if things got out of hand. Nvidia can go play Russian roulette in their own homes if they feel that safe with it, sorry not me and I have been into computers for over 3 decades professionally and 4 decades as a hobby too and never seen anything like this mess before and not even recalling it and blaming end users as their fix to a clear problem that should never have been allowed to happen, even if it allowed end users to such a dangerous mistake it means it is not fit for purpose on a consumer based hardware that joe/jane public install in their computers. Just waiting for the day this ends with the death of someone then they may wake up sadly. Anyways not for me this game of burn your house down roulette .. 50 series either new safe connector or back to 8pin and 6pin or I'm out again till their is enough proof this has been resolved.
I would feel very if the OP received his card back but with the older defective 12-pin connector.
Hi mate, yes with those cables Nvidia will probably void your warranty. The company is called B-Hawk Gaming based in Wales they repair CPUs, GPUs etc, very good reputation.So reading your post (I'm sorry you had to go through this nightmare) I'm taking a few things from it. I'm currently using Cabelmod braided cables pci-e for corsair 16-pin to 3 x 8 pin and I'm guessing by doing so if same thing happens to me I'm voiding my warranty with Nvidia? I'm using an 4090 FE by way. If this is so I'll go back to Nvidia octopuses adapter. Can you name the repair company for future reference in case it happens to any of us and tell us what the cost is please.
well I've had zero problems but after that bombshell the cablemod cable will have to come out. I'm actually surprised at that price £120 is very reasonable. And hopefully cablemod will sort your costs. And you'll get a working card back again and I trust you'll be doing the same thing as me.
