 - 30 Mar 2020
I've not under volted the card. I'm close to putting my 3090 back in.What cpu cooler and what temps are you seeing in games.
remember the 4080s is only about 13% faster than a 3090, ive seen a few review's online says the power phases have been cut back, have you undervolted the card with curve optimizer, you could be hitting the power limit??
if you monitor is 165Hz it's advised you set a max of 164 in control panel as setting it the same as the refresh rate can cause visual problems
(this is apparently a know problem) i was told to do this when asking or the cap FPS in loading screens
