4080 super running like crap
This is what I can find the bios. I have to run it on the middle setting as nothing else loads and just returns me to bios.
The mother board is a rog hero maximus xiii if that means anything.
Sorry about this guys I'm just lost as I know this isn't running right.
The M.2 slot: M.2_2 shares bandwidth with the PCI-E full length slots 1 & 2. If you enable the option highlighted in red in your screenshot: then you get 8 lanes on your primary slot, 4 lanes on the second and 4 lanes for your M.2 drive in M.2 slot 2.
If your PC does not boot into Windows with any other setting, I would assume you have a M.2 drive installed into slot M.2_2.
If so, this is not an issue and while some performance loss will happen running @ 3.0 with only 8 lanes, it should not be terrible (in TPU's testing with a 4090, they lost a maximum of 8%).
streaming is very CPU intensive, you said your seeing 100% on the CPU when streaming...
this is why i said for your use case i would grab a 14700k or 7800x3d
streamer's run a second system.
my buddys son as a
11700k / 4070 and
9600k / 2070
the latter is the capture system
Kitguru’s Matt demonstrated that a 13500 is perfectly adequate for streaming.
Reseated the card.
Preformed another ddu.
Put hdd and ssd in the 2 bottoms ports on the mother board. One was in the middle. No longer on m2_2
Still on x16 3.0 but does drop to x16 1.1 when not under load.
my buddys son as a
11700k / 4070 and
9600k / 2070
7800X3D is way behind the 14700K, 7950X3D, even the 7900X when it comes to gaming + streaming - despite the hype on the 7800X3D they are a bit of a one trick pony really. The encoding performance can be as much as half those other CPUs and/or the impact on gaming performance when doing both (depending a bit how much you are making the GPU work for encoding and/or using an additional GPU for it).
EDIT: If doing 1080p capture with an additional machine you don't need anything crazy CPU wise, but resolutions above that another matter - I'm generally using the laptop in my sig with an ancient i7-3610QM for 1080p, only bother with a higher spec system for 4K capture/streaming.
I have it now booted on the top option not the m2_2 all the drives are in m2_3 and m2_4
yes i just sold a 13500 set up in the MM and i can defo say its an Amazing CPU when working with DDR5. i fold at 1080p it would sit at about 80% CPU usage i wouldn't personally put streaming load on top of that, but at 1440p the CPU would sit back and relax pumping out 165fps
i wasn't saying one is better than the other but if i was dropping 1k into the system he as for gaming i wouldn't be replacing 3090 i would be trying to move over to DDR5 based system. the AMD chip is very good for gaming. but yes intel dose tend to be the choice of most streamers, just like NV is too
also wasn't saying he needed two system i just pointed out most streamer that are trying to get to the top run two in some way.
my buddy son just reused his old system after upgrading
N.i
I'm not trying to get to the top mate I just do it for complete fun. I also don't want another system.
