Deleted User 298457
Deleted User 298457
OP
Can you link to the rubber roof supplier you used?
Garden Room Roof Kits
Roof Kits for free-standing garden rooms where the gutter runs along the long edge.
Ah fantastic that looks like it comes with everything and is cheaper than the EPDM roof supplier I had looked at.![]()
Roof Kits for free-standing garden rooms where the gutter runs along the long edge.www.rubber4roofs.co.uk
There is a discount code for Oakwood too - LIAMFB5Ah fantastic that looks like it comes with everything and is cheaper than the EPDM roof supplier I had looked at.
I was a bit "uneasy" about this too but its been pretty straight forward. I ordered these bits from plasticshub:
Then some polytop pins (Wickes stock them). Basically attach soffit, then attach fascia, use the joining bits/corners as required, then buzz the excess of with a multi tool so it fits level with roof. Done.
The rubber roof then comes with bits that cover the rubber once it is folded over the top of the fascia.
Edit: guttering I am not thinking about yet but have my Wickes basket ready.
Yeah you need both. Caught me by surprise too as I hadn't budgeted anything for fascias, soffits, or cladding lol.Just seen your roof postings below...
Does that mean you need to buy both for the roof. Circa 1.3k? Oof.
Maybe I should have clenched harder when I bought the build pack haha some expensive gear but I suppose it's the main thing you want to work as intended.
Did you look at permaroof options also?
It was only 350 for soffit/facias tbf.There must be cheaper sources of the soffit and fascia boards. I see advertisements on Facebook all the time for a whole semi detached house soffit fascia and guttering replacement for £1000 all in Inc labour obviously.
Edit: no I didn't check permaroof, I went straight to Rubber4roofs. I don't think the permaroof one is as "complete" as the R4Rs but that's just an anecdotal statement. I pinged a guy in the trade and he was impressed with what they sent me basically (he uses permaroof).
I've used Permaroof for 4 roof areas now:Just seen your roof postings below...
garage at approx 7.6m x 4.5m
Garden gym 6m x 3.5m
Garden room 8m x 3.6m
Extension 9m x 3.8m
Comes as complete kit, went with the thicker rubber option and straight forward to install.
Most times when you're emailed the quote, there is a 10-15% discount if you order within a particular timeframe.
Here's a couple of prices for reference, these are the sizes after they add on approx 300mm:How much was the garden room one? Just to get a flavour of cost?
I presume the build pack tells you what roof bits to buy @dlockers ?
You can key your dims into rubber4roofs and it'll build a full kit.How much was the garden room one? Just to get a flavour of cost?
More importantly have you thought about solar panels for the roof........I'm obsessedYou can key your dims into rubber4roofs and it'll build a full kit.
Need to get them on the 13m workshop first!More importantly have you thought about solar panels for the roof........I'm obsessed![]()
I started on one roof, now over 4 areas and a wall -39 panels and counting (I'll top out at 48 it seems).Need to get them on the 13m workshop first!
I might owe you a beer or a steak dinner...I need someone to give me some coaching on how to get my 13m workshop covered in them!I started on one roof, now over 4 areas and a wall -39 panels and counting (I'll top out at 48 it seems).
What kind of roof, flat/pitched?I might owe you a beer or a steak dinner...I need someone to give me some coaching on how to get my 13m workshop covered in them!
Edit: I need to find someone who can endorse the roof is strong enough though!
It's a pitched cement fibre roof supported by a wood frame at 2ft centers. The initial spam is 12ft but then the next ones are 10ft.What kind of roof, flat/pitched?
Type of finish, felt/EPDM/corrugated sheets/tile/slate?
Do you know the span, size and centres of the beams?
Are the roof areas East and West? Some serious potential if they are - possibly 10/11 panels per side in portrait position.It's a pitched cement fibre roof supported by a wood frame at 2ft centers. The initial spam is 12ft but then the next ones are 10ft.
It's 3m width.
