You did good! All that extra bloat is a PITA. Switching between inputs still annoys me. Better than it was tho now that they have unique names and don’t swap positions.I managed to snag a bit of a bargain last night with a G93SC for £647 direct from Samdung. I liked the G95 when I tried it some time back but absolutely hated the smart menu ******** but fortunately this doesn't have it![]()
WHAT THE !!!I managed to snag a bit of a bargain last night with a G93SC for £647 direct from Samdung. I liked the G95 when I tried it some time back but absolutely hated the smart menu ******** but fortunately this doesn't have it![]()
Not one bit. Way too big and the gfx power to push that many pixels is insane!!Where you tempted by the 57 inch?
out of Interest what are your main games you play and are they compatible with the 32 9 ratio for this g9Not one bit. Way too big and the gfx power to push that many pixels is insane!!
Not all of them no, but at worst I'll play at 21:9 and at best I'll be able to utilise it fully which is fine with me. When it's all being used it just looks fantastic!and are they compatible with the 32 9 ratio for this g9
As far as I know newer Samsung qd-oleds perform a mini-cycle each time you turn them off instead of periodically. They will only ask you if you turn them off at the wall socket which stops them from doing their mini-cycles on standby.I still can't figure out if this monitor does its cleaning cycles or not He's never asked me anything and I'm basically going in blind.Not even the LG C2 asked for it but I was on the safe side with them, much less so with Samsung to be honest...
Hows the 49 going ? What a bargain thoughNot all of them no, but at worst I'll play at 21:9 and at best I'll be able to utilise it fully which is fine with me. When it's all being used it just looks fantastic!
Yeah I couldn't get on with it as found it just too wide so I did a deal and swapped it for a G80SDHows the 49 going ? What a bargain though
It didn't have a 3440x1440p setting in the EDID so that killed it for me
