Do you have any CO2 canisters you can use to try and get it seated?
No nothing, was reading about Airshock but going to try again when i get my spare wheelset from storage and don't have the worry or being without bike!
Oh for sure, I keep saying it - "without Zwift, I'd be nowhere" - the reality of that is the convenience around massive flexibility in riding, but also with things elsewhere so I can jump on. The regularity of riding the same evenings timeslots every week for 1-1.5 hours and getting a Race/TTT done is great. As without it - I would be riding far more sporadically (couple of times a month, rather than couple of times a week!) due to the longer hours needed outdoors and have a much lower fitness level...I don't know how people do it who don't have a vaguely flexible schedule. The weather in the UK is so erratic 10 months of the year.
You're getting there, some good rides done already, you had such a massive base of fitness before from all the years of commuting. Very hard to get back to that level without a huge time investment - so don't even try! Find your 'new level'I'm still very much in "trying to get my legs back" phase so short rides at lunch work okay. I'm sorta hoping I can get fit/fast enough to get 20k ish in an hour during lunch. That'd be perfect.
I don't, although I've got a torque that goes to that far, but not the lockring tool which will fit it - just the long handled ratchet/wrench type. I've never had one come undone/loose. As they've got those ridges on, once you get towards 'grunt' tight I find then tend to 'sit' into a notch. I then go 2 more. Around the tightness I'd call '2 grunts'! But I have got sparrow strength arms these days!Does everyone have the relevant tools to put a disc on to 40nm, or do you just put it on 'tight' (I only have a small torque tool for the 4 and 5nm bits)
Still some SL7's around some good deals on them, for very little difference (Di2 vs AXS & stick some good wheels on it they're the same bike)... I only know 1 guy locally with a Soloist, not really talked much about it but he seemed to loving it. See lots of influencer types with them, but as for 'real world' owners... Not sure where you'd find them.Does anyone own or have ridden a Cervelo Soloist?
I'm in the market for a new bike and it seems to fit the criteria of being a great all-around road bike that is easy to work on. I'd appreciate any real-world experiences/thoughts.
I'd like an SL8, but the price has gone up for the 2025 version and there are not many 54 frames left at the discounted price.
Yeah still not a fan of the big nose...! But it's far less obvious when you're stood around it (in LBS) - looks very obvious on Andy's picture! Still love his paint...I just can't get on board with the "speed sniffer on the SL8
Warm it - indoors. Fit it with tube at 100psi, leave it 24-48h, then taken it off, remove and immediately reinflate as tubeless. You shouldn't need sealant to mount it - actually with one that tough better it seats without.Just couldn't get the bead to sit in the rim all the way around, i then hoped it might sort itself out and stupidly cracked on, only for sealant to squeeze out everywhere when i tried to pump up. I regularly have similar issues with these tyres when changing a tube but then getting it up near 100psi pops it into place. Not a luxury i have with tubeless as the air just escapes under the tyre before i can get any pressure up.
Will have another bash sometime. I've seen suggestions of suspending the wheel so there's no pressure from the floor so might try that. For now i'm just going to clean up and get the tube back in to ride at lunch.
And this is always my problem. I generally have a bit more 'grunt' than the average person (let alone the average cyclistonce you get towards 'grunt' tight I find then tend to 'sit' into a notch. I then go 2 more. Around the tightness I'd call '2 grunts'! But I have got sparrow strength arms these days!![]()
I thought seriously about the SL8 Expert as you can pick that up for under £5k in some stores. My issue with it is that I don't want Rival Axs, it is objectively heavy for a groupset. I know I could eventually replace the parts, but this is at a cost. I'm also not sold on the nose of the SL8 but I suspect it looks less prominent on smaller frames. The SL7 is a great shout but it's a lower-tier groupset and I'd have to spend money on replacement wheels. I've managed to get the Soloist for £4,700 which comes with Ultegra Di2 and Reserve Carbon wheels which are (apparently) great The only aspect of the bike that needs an upgrade is the handlebars, but this is fit-dependent. It's not worth the RRP of £6,800 (but this can be said about most bikes these days) but I'm happy with the deal.Still some SL7's around some good deals on them, for very little difference (Di2 vs AXS & stick some good wheels on it they're the same bike)... I only know 1 guy locally with a Soloist, not really talked much about it but he seemed to loving it. See lots of influencer types with them, but as for 'real world' owners... Not sure where you'd find them.
my mate is looking to upgrade from SL7 Sworks to SL8 and is trying to sell his frame with Darimo Seatpost.Does anyone own or have ridden a Cervelo Soloist?
I'm coming from a 2017 TCR Advanced Pro (rim brake). It's been a great bike but I'm now craving, discs, di2 and wider tyres.
What do you mean? I have Ultegra on my Tarmac SL8?For the 8 the have switched to the SRAM rival group set
If you like Trek, stick to trek.I’m currently riding a trek domane sl5 in a size 47, looking at getting something a bit faster and sportier next year where would you go with a 5-6k budget.
I was looking at a trek madone sl7 gen in xs, tarmac sl8 expert in a 44 or cannondale super six evo 2 in a 48.
When comparing geometry I have shorter legs so finding frames that I can stand over with both feet seem to be a challenge and always need to size down based on a manufactures recommendation based on my height of 165cm and an inseam of 70cm
You got the expert?.What do you mean? I have Ultegra on my Tarmac SL8?
I have the Pro.You got the expert?.
Yes, there are brands where you pay less for name and get more for moneyWhat I meant was the older Experts were Ultegra. The SL8 is now Sram rival which technically is a downgrade in spec, without the reduction in price. Hence the similar priced Madone looks like a better buy. However not entirely convinced that the downgrade would translate to any big real world differences for us mortals.
You can understand my confusion, as this statement doesn't look to be correct. Should it be SL8 Expert? Is that what you're saying?The SL8 is now Sram rival
OkYou can understand my confusion, as this statement doesn't look to be correct. Should it be SL8 Expert? Is that what you're saying?
Even then, there's this SL8 Expert with Ultegra Di2?
Tarmac SL8 Expert - Shimano Ultegra Di2
Nothing is faster than the Tarmac SL8 thanks to a combination of aerodynamics, lightweight, and ride quality previously thought impossible. After eight ...www.specialized.com
It is available in Sram Rival, but it is cheaper, as it is a downgrade. Sorry, maybe I'm being stupid or missing something?
Sorry, maybe it sounded like I was being pedantic, but I just didn't understandNo problem, makes sense now, thanks.
**EDIT** To add to that confusion, mine is a 2024 SL8 (Pro) and is Ultegra Di2![]()
