Caporegime
- 18 Oct 2002
The fps below 50 is noticeable
Do you have Gsync? It realllllllly helps with the lows!
This could be the beginning of the end got my 4770k / 8GB DDR3 2133MHz PC... Ive not run into any problems before in achieving a smooth 60fps on highish settings with my 390x (which is now dead anyway).
Using a temporary 780 it runs between 30 and 50fps avg @ ultra . with everything on low inc textures I get close to a 60 avg . doesn't seem massively scalable to me
There is a massive difference reported on FPS even with people on similar hardware. Makes me wonder if the people claiming higher are playing on a low populated server or sniping from afar. If you are running round with explosions etc going off that will tank the frame rate.
seems like games and apps have now been starting to push bandwidth limit much more than before, with Intel I have seen reviews reporting up to 39% more fps when overclocking the ram from 2133 to 4000.
For example:
2133 to 3200 causes 20-25% increase, 2133 to 3600 causes 26-31% increase and 2133 to 4000 causes 32-39% increase in average and min fps.
Source: http://oc.jagatreview.com/2018/07/h...-skill-sniperx-ddr4-3600cl19-16gb-kit-2x-8gb/![]()
Although timing is still pretty loose since the ram is hynix C-die, good b-die should do 3600mhz 15-15-15-35-1T and 4000mhz 17-17-17-34-1T pretty easily.
This makes me wonder what a good setup with good b-die + single dimm board + good CPu really can achieve. Something like 5.4Ghz core 5Ghz cache and 4400Mhz 18-18-18-36-1T tight would be amazing![]()
there are two or three occasions where the frame rates go as low as 55 FPS without any stutter. so that's what i'm going with.But they have more than enough money pushing for not worthy boards like Gigacrap, MSI goatlike, mAxIMuS FoRMula/exTRemE, etceveryone always looks at the highest frame and average but never the min FPS
tend to push 8 packs 4000 kit because of it - give you a large scope . Shows why Intel always caps their B/H boards to lower ram speeds but unfortunately, most people don't have the budget to stretch for fast ram![]()
with black pcb B-die sticks, the board is the limit not the ram@humbug The game needs lot of work, there are plenty of bugs causing stuttering not your system
7700k maxing on all 8 threads getting upto a toasty 80 degrees!!
Might need to replace air cooler with liquid AIO![]()
Good to know that snipers and supports can afford to cheap out on PC components compared to tanks and warriors.![]()
Not what I meant but yeah!!
@humbug let me know if you do a 720p run. I'll do the same. Make this thread interesting!
