- 24 Sep 2013
- Exmouth, Devon
Hi,
So, just bought the game. I'm using an LG C2 42 inch and windows 11.
I have windows HDR on, Auto HDR on.
If I turn HDR on in game it just looks reallllly washed out. I figured, okay that's the aesthetic, got to the outside world after the cave of knowledge and it just seemed really off, I figured it should look "beautiful" but it didn't.
Turned off HDR in game and the picture looks so much better, vibrant.
So, is HDR broken, have I set it up incorrectly? What's going on here?
You don't use windows night light modes do you? Mine goes orangey with HDR on and night light on (same TV). Also as the game is capped at 60fps, you can use this for other game options - just not if you want to play it online.
GitHub - uberhalit/EldenRingFpsUnlockAndMore: A small utility to remove frame rate limit, change FOV, add widescreen support and more for Elden Ring
A small utility to remove frame rate limit, change FOV, add widescreen support and more for Elden Ring - uberhalit/EldenRingFpsUnlockAndMore
