To be fair, I just need to get a proper focus for a night or so but it just comes across so utterly unforgiving right from the start that I can't find the patience for it.
The game is brutal hard.
I gave up on it within the first 2hrs. Far too hard.
But I only tried it again because I paid £35 for it so I just wanted to get maybe 10hrs of game play out of it so I could tell my self I got my moneys worth.
In the end I played it about 160 hrs in total.
The boss fights are extremely difficult in this game. But that's the point. You get such a sense of elation and achievement when you do finally kill that boss.
In Elden Ring the bosses are hard. But the difference is in Elden Ring you can just go and farm levels to come back stronger which is what I did.
But in Sekiro there is no levels. You just unlock prophetics to use, so basically you are forced to learn the boss.
The fights are truly some of the most epic you will ever play.
Heres a selection:
(The above has three phases! You get through rounds one and two by the skin of your teeth then the guy comes back and starts firing lighting at you! Its ridiculous!)
The above videos look easy because the player is well practised and skilled and knows exactly what to do.
These fights will take you a long time to master.
Edit I said above that you dont level up in Sekiro. Having played it a few years ago I think I misremembered. There are XP levels in Sekiro its just not as obvious as in Elden Ring.
