- 13 Apr 2019
- The cold wet North East of England
What’s the stuff that Dignitas use for assisted suicide at their clinics?
yep its the same gas used, so as far as I’m concerned, if its good enough for assisted suicide, it’s good enough for some dirty Murderer, Rapist, Pedo
Sarco pod - Wikipedia
en.wikipedia.org
Dignitas typically uses an oral dose of an antiemetic drug (to prevent vomiting up the lethal drug later), followed approximately half an hour later by a lethal dose of 15 grams of powdered pentobarbital dissolved in a glass of water. That is probably the best way to go, as you go to sleep, then slip into a coma and die painlessly. (The barbiturate overdose causes the heart to stop beating.)
The same drug is used for physician-assisted death in Holland, Oregon, Washington, Vermont and California. The problem is that Pharmaceutical companies won't sell it to the Department of Corrections because they don't want the bad publicity from it being used in executions.
