- 18 May 2010
Isn't the Alienware qd-oled 34" and ultra wide?
It is. For a while I thought there might be a 4k 32" one so, but I think he just got confused.Isn't the Alienware qd-oled 34" and ultra wide?
I have a 4k 40 inch right now and it's perfect for me even though I sit less than a meter away from itI think you might find even an 42" too big for your daily user. I had an 48" and even 1.5 metre back it was hellish on the eyes and brain and I didn't even use it as a daily but as a secondary display, daily is my 28".
I think the sweet spot would be an 31-34" for an daily, secondary 38-42"+ for a secondary.
But its different for everyone, viewing distance, room layout and usage are big factors in it. Console gamers with space could do an 65" probably.
If you wish to get an idea check the dimensions of an 42" OLED LG (932mm by 540mm) and cut a cardboard cut shape of it and stick it where you would normally be seated to get a rough idea of the sheer scope of it. Its not ideal but it will give you a idea to work with.
Yea, figures as much, but did get me excited for a split second.Typo in my post meant the 34 inch qd-Oled one here
https://forums.overclockers.co.uk/t...sung-34-inch-ultrawide-175hz.18945041/page-12
At a reasonable competitive price as wellYeah that is good, as I was saying its different for everyone some love it and some hate it, its almost like marmite.
Hopefully we reach a point in the next few years manufacturers make OLED or QD-OLED screens from 31-42"+, that way we have the choice at least.
Same here, man. I still like to play a lot of old games and they simply don't support UW. Or I must use mods to make it work but that doesn't always with a success.Well dumb me that dident try this!
So now I will never touch the Alienware. I will go for the C2. Need that space, there simply is no way around it!
Update: Totaly changed my mind - for what it's worth!
Tried some gaming tonight on my PG279Q - same vert space (fov) as this UW, as we know!
I hated the bloody supersmal fov. No way I can live with that, no matter how good it May be!
So I will Definetly go for the C2 42 incher, and be immersed!
I can't help feel that I'm now being draw to the 48 inch C1 at under a grand now though
Yeah for sure. But if one can wait I am almost certain within 12 months it will come down to a three figure sum unless demand remains crazy high.Oled 42 available to preorder at same place as the 48... and 1399 as well.
The alienware at 1099 looks better value for sure.
Yep. That's my thought. If I can get the Alienware at a discount I will be buying it on day one. Can see what's what and if I like then job done, if not just wait for a bargain on the LG displays.Thinking the same @TNA.
Although if the Alienware one gets a decent review, will look into them discount avenues as that may bring it down enough to trigger.
