- 22 Mar 2009
U a sad evil twist!
I would raise a fault with your ISP/OR immediately.![]()
Just had Sky Fibre Pro installed, how do these stats look?
Attainable rate (kbit/s) 107816 39717
SNR margin (dB) 13.9 18.6
Line attenuation (dB) 0 0
Output power (dBmV) 12.8 5
Line rate (kbit/s) 79987 20000
CRC errors 0 0
FEC errors 19 0
HEC errors 192 0
These look superb. No CRC error on the line. Plenty of room for any future crosstalk with your noise margin of 13.9dB. Excellent line. Your is much similiar to my line too.
What are you talking about? Your line is shocking!
Have you raised a fault yet with your ISP/OR?![]()
Very funny u are!![]()
Max: Upstream rate = 13159 Kbps, Downstream rate = 39828 Kbps
Bearer: 0, Upstream rate = 13244 Kbps, Downstream rate = 38678 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Down Up
SNR (dB): 6.1 6.6
Attn(dB): 20.6 0.0
Pwr(dBm): 13.7 6.8
6. Data rate: 15071 / 43225
7. Maximum data rate: 14777 / 41090
8. Noise margin: 6.1 / 6.0
9. Line attenuation: 0.0 / 20.9
10. Signal attenuation: 0.0 / 21.1
HG612 vs HH5
Code:Max: Upstream rate = 13159 Kbps, Downstream rate = 39828 Kbps Bearer: 0, Upstream rate = 13244 Kbps, Downstream rate = 38678 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Down Up SNR (dB): 6.1 6.6 Attn(dB): 20.6 0.0 Pwr(dBm): 13.7 6.8
Code:6. Data rate: 15071 / 43225 7. Maximum data rate: 14777 / 41090 8. Noise margin: 6.1 / 6.0 9. Line attenuation: 0.0 / 20.9 10. Signal attenuation: 0.0 / 21.1
Is that your line?
What cab brand are you on?
Had my Infinity 2 installed today. Not unlocked the HH5, but would be interested to see what you make of these stats:
Data rate: 7578 / 54033
Maximum data rate: 7902 / 51903
Noise margin: 6.2 / 5.3
Line attenuation: 0.0 / 23.1
Signal attenuation: 0.0 / 20.9
I was estimated speeds of 76Mbps but actually getting around 50Mbps.
I'm approx 450m from the fibre cabinet, so just wondering if my stats and download speeds are as a result of that.
I
If my current speeds are due to my stats and distance from the FTTC cab then I'll just have to accept it.
